  3. Send Large Data From Client Side To Meter
Send large data from client side to meter
By Dmitry , 3 April, 2023
Hi, Mikko!
I try send large data from client to meter.
I do it:
CGXByteBuffer bb;
auto str = data_for_send.toByteArray().toStdString();
bb.AddString(str);
CGXDLMSVariant v(bb);
std::vector<CGXByteBuffer> data;
if(int ret=gcl->Write(obj, index, v, data); ret != 0)
qDebug().nospace() << "Failed generate message for write object " <<
obj->GetName().ToString().c_str() << " Error: " <<
CGXDLMSConverter::GetErrorMessage(ret);
else
send_data(data); // send data to meter
exchange:
TX: 7ea07f020161fc862ae6e600c10181000100006001feff02000963ef1c04e01080218025e0120881888189818a818b818c828883888488068b788178837889788e788d780c9f78b378c778a078b478c8789578a978bd789778ab78bf78028091809203e051e052e05305480112004802120048031200480412004801120189887e
RX: 7ea0086102019764e47e (UnacceptableFrame)
But if i send large data from anoter client (witout gurux lib) exchange like this:
TX1: 7ea878000200016170235fe6e600c101c1000100006001feff02000963ef1c04e01080218025e0120881888189818a818b818c828883888488068b788178837889788e788d780c9f78b378c778a078b478c8789578a978bd789778ab78bf78028091809203e051e052e05305480112004802120048031258117e
RX1:
7ea00a61000200013108947e
TX2: (send remaining data)
7ea01500020001617247db004804120048011201127c7e
RX2: OK
How can i split large data?
vector data has only 1 element after call Write() function.
Thanks!
Dmitry
3 years 7 months ago
Data for send in hdlc packet…
Data for send in hdlc packet:
Hi, The meter return maximum…
The meter return maximum frame size when connection is establieshed using UA message. Your meter returns frame size that it can't handle. You need to fix that for the meter.
Dmitry
3 years 6 months ago
Hi, Mikko! I got 2 packets…
Hi, Mikko!
I got 2 packets in vector data after call Write() function. I send first packet and meter answer:
TX: 7ea875020161fc7647e6e600c10181000100006001feff02000963ef1c04e01080218025e0120881888189818a818b818c828883888488068b788178837889788e788d780c9f78b378c778a078b478c8789578a978bd789778ab78bf78028091809203e051e052e0530548011200480212004803c6997e
RX: 7ea008610201f154e27e //ok, need next frame
But how to parse this RX answer for send next part of data?
I call GetData(reply_buf, reply, notify) but reply.IsMoreData() returns false, reply.GetCommand() returns DLMS_COMMAND_NONE.
Thanks!
Hi, You don't need to split…
You don't need to split it. The wramework splits the data to PDUs and frames automatically for you.
Just add data that you want to write and call Write.
https://github.com/Gurux/Gurux.DLMS.cpp/blob/b779568dc96ccb07bba10a077c…
