  3. Add Device - Not Displaying Form Inputs
Add Device - Not displaying form inputs
Profile picture for user tukur
By tukur , 29 March, 2023
Gurux.DLMS.AMI
My app is running perfectly in a docker container except that my Add device page is not showing the form input. It's just a blank page.
How can this be resolved, please?
3 years 5 months ago
Hi, This can be repeated…
This can be repeated. The reason is not quite sure yet, but I keep you posted.
tukur
Thanks @Kurumi, I look…
Thanks @Kurumi, I look forward to your useful contributions
In reply to Thanks @Kurumi, I look… by tukur
Hi, This is on testing at…
This is on testing at the moment and the new version is released later today.
tukur
In reply to Hi, This is on testing at… by Kurumi
Compliments of the day, I…
I have pulled the updated one. This is the error I'm getting
An unhandled exception occurred while processing the request.
InvalidOperationException: No signing credential is configured by the 'IdentityServer:Key' configuration section.
In reply to Compliments of the day, I… by tukur
Hi, This is fixed. Microsoft…
This is fixed. Microsoft has made something and you need to add this parameter.
-e "IdentityServer:Key:Type=Development"
I don't know the reason for this at the moment and why it works without this fix with some PCs.
This parameter is now also added to docker help.
https://hub.docker.com/repository/docker/guruxorg/guruxdlmsamiserver/ge…
tukur
In reply to Hi, This is fixed. Microsoft… by Kurumi
Good day, I pulled the…
Good day,
I pulled the latest image today, 4/4/2023, and run it.
I still can't see the Add Device form and when I try to add a device template, I get an error "Value cannot be null. (Parameter 'Array is empty.')"
In reply to Good day, I pulled the… by tukur
Hi, Do you have any data in…
Do you have any data in your template? Can you share it so we can test with that? I just test this with clean database and the latest docker and it worked without problems.
tukur
In reply to Hi, Do you have any data in… by Kurumi
The only data I'm using is…
Wait time: 5
Resend count: 3
Just want to see it work, then I will create a device, but even the Add Device is empty as I told you.
I'm using windows 11
In reply to The only data I'm using is… by tukur
Hi, Now I know what you have…
Now I know what you have done. You have created a device template, but not selected the file that contains meter information.
Remove your device template. Then connect for your meter with GXDLMSDirector and save it. Then select that file and import it so device settings are updated.
DLMS meters are very different and without that information it's not possible to connect for the meter.
I created an issue that device template can't be added if device settings file is not selected.
https://www.gurux.fi/issue/guruxdlmsami4/20713
tukur
Thank you for your…
Thank you for your explanations.
Do you have any working template that you can share with me so I can try it from my end?
If it works, then I will try configuring my meter following the settings from your template.
thiesens
I also get the error "Array…
I also get the error "Array is empty".
I tries in the ui, directly using api, and I also now get it when adding an agent.
Hi, I have send the device…
I have send the device template for you by email. I also removed your email address so you don't receive spams.
Hi thiesens, Please, in the…
Hi thiesens,
Please, in the future create a new topic if you have a new question. You will receive reply faster and correct answer.
Get the latest versions from the docker and agent and let me know if you have any problems.
tukur
Thank you @Kurumi When I…
Thank you @Kurumi
When I want to add the template you sent me edmi.gxc, I'm still getting the error
Hi, I created a new database…
I created a new database and pull the latest docker version and it work as expected.
I used the same name and template as you did.
One fixed issue could however appear like this. If your user name was too long it caused problems and this is fixed for the latest version.
Can you pull the latest version and create the database again?
If you still get this error can you send the content of the system log to me?
SELECT * FROM GXSystemLog
This can be fixed as soon as this can be repeated. :-)
tukur
It has worked now, but when…
It has worked now, but when I came to running the agent. It said "fail: Gurux.DLMS.AMI.Agent.Program[0]
Access to the path 'C:\Windows\agent\settings.json' is denied."
3 years 4 months ago
Hi, Is settings.json file…
Is settings.json file exists? Try to remove it and try again.
