  3. DLMS Android - ProfileGenerics - ReadRowsByRange() - "Failed To Get The Certificate.
DLMS Android - ProfileGenerics - readRowsByRange() - "Failed to get the certificate.
By sachinar007 , 16 March, 2023
Gurux DLMS for Android
Hi Sir,
Please find Block Cipher and Authentication Keys(kept both same only) - 1234567812345678
We are trying the same thing as reading works if we use "readObject(profileGeneric, 3);(Capturing Objects)" and "readObject(profileGeneric, 2);(The Buffer Data)".
But it returns Exception like "Failed to get the certificate." from GXDLMSSettings.java class when we try to call "byte[][] data = mClient.readRowsByRange(pg, start, end);" OR "byte[][] data = mClient.readRowsByEntry(pg, 10, 10);"
Here is the Calendar date config...
readObject(profileGeneric, 3);//Capturing Objects first as expected
Calendar start = Calendar.getInstance();
start.set(Calendar.HOUR_OF_DAY, 0);
start.set(Calendar.MINUTE, 0);
start.set(Calendar.SECOND, 0);
start.set(Calendar.MILLISECOND, 0);
Calendar end = Calendar.getInstance();
end.set(Calendar.SECOND, 0);
end.set(Calendar.MILLISECOND, 0);
byte[][] data = mClient.readRowsByRange(pg, start.getTime(), getTime());
//////////////////////////Please find the Trace from GXDLMSDirector below////////////////////////////
16:26:52 Read object type ProfileGeneric index: 4
TX: 7E A0 2C 03 61 54 9C BA E6 E6 00 C8 1E 30 00 00 00 76 65 46 E1 D0 7E 96 75 E5 D8 02 FB FC 20 59 6C A3 B0 A1 25 1C FF 4C F6 8C 0B 6E F1 7E
16:26:52
RX: 7E A0 28 61 03 74 62 0F E6 E7 00 CC 1A 30 00 04 0A F0 46 D4 BD B9 AA AB 42 63 7A 81 36 C4 C2 FE 05 8A BA 78 60 9F 90 F1 62 7E
16:26:52 Read object type ProfileGeneric index: 5
TX: 7E A0 2C 03 61 76 8C B8 E6 E6 00 C8 1E 30 00 00 00 77 04 DE 07 98 73 17 B2 85 B9 ED 02 20 4C 4B ED 23 DC 26 47 86 95 D2 A3 FE BA 1C 80 7E
16:26:52
RX: 7E A0 25 61 03 96 F1 40 E6 E7 00 CC 17 30 00 04 0A F1 E8 7D 08 13 CF 49 24 55 13 01 2B 65 EB 87 B8 A8 81 27 A6 C8 7E
16:26:52 Read object type ProfileGeneric index: 6
TX: 7E A0 2C 03 61 98 FC B6 E6 E6 00 C8 1E 30 00 00 00 78 01 9C 4F B6 83 C6 BF 9E 99 73 CB CE 0E 3A 09 AD A8 EB 5C 0C F3 8B 22 E8 6B 56 D4 7E
16:26:52
RX: 7E A0 35 61 03 B8 2C 4B E6 E7 00 CC 27 30 00 04 0A F2 39 8D 0F 90 79 9F EE A0 FE 8F BE 6A 6C 13 17 30 B2 74 CD 0C 97 F9 49 E1 52 36 66 B1 C9 68 6C 1C 88 73 2C 8A 7E
16:26:53 Reading profile generic data
TX: 7E A0 5F 03 61 BA 64 CB E6 E6 00 C8 51 30 00 00 00 79 49 75 1E 7B C8 AD DE 46 70 B9 EE 55 54 FB CE 11 00 B8 FF 1E EB D4 47 2D FF A4 B7 96 40 86 B8 49 32 B3 6C 4E 9F A6 58 3E BB C0 51 4D EB CE 1F 80 41 93 1C 86 B8 01 82 15 BB 75 FC 67 27 67 C1 00 78 13 09 31 A8 A7 42 D8 D4 68 B4 AE 6E 0F 7E
16:26:54
RX: 7E AA 4C 61 03 DA B6 E4 E6 E7 00 CC 82 04 30 30 00 04 0A F3 AB A4 29 E2 6C 57 52 60 DA 71 EA A3 FF F4 42 A8 DD 02 B9 03 C3 8D EF F0 2D 44 E9 A4 BA 6C F1 2E A5 ED 71 7E C7 63 0A 24 0B 8D 3C AC 0F 3E 76 49 80 0F 38 0F 02 D4 B5 BB 73 60 E0 F1 90 7D 42 E2 91 D7 99 6B F1 91 DE E4 C2 44 FF 07 F2 BC 25 85 00 7A 16 12 5D 97 FA FC 07 62 93 7A 87 81 87 B1 77 74 55 0C 10 54 8E 47 AF 5C 6F 8A 7A 86 20 90 9C 2A 2B 85 01 89 E1 50 B3 95 8A BF 09 89 03 8D 76 A4 34 9A B3 B5 39 55 34 41 66 1F 25 F5 7D 10 34 E6 36 48 20 69 88 E5 72 DD B1 72 2C 50 77 6E FC 6E 42 B1 E0 51 C0 5D 54 43 66 83 3F 29 D4 ED 7D 89 77 84 29 01 0E 03 08 15 72 FC 35 5D 91 51 9F DA E7 42 74 CA C4 3A F1 1C 22 11 39 4A 5C AE D2 B4 EB D3 8D 69 09 E9 2D 17 F2 5B 54 9C C7 3A ED 5E E7 BA 43 E7 6D E7 CA 09 27 BA 56 48 07 09 F6 15 BC 38 02 D7 85 39 8C D8 BF 10 EA B6 92 4F C5 55 D9 5C 37 7F 5E C2 76 56 60 61 13 D0 E8 22 C6 BF 15 A6 38 A8 F0 53 49 AB EE 66 26 E8 5A 6F 36 1C DA 6E 39 C9 44 BA 47 75 17 10 42 D3 77 A4 F8 63 1B 49 D6 32 7D 55 61 A0 42 27 24 DF 9A A0 9E 62 20 4B A3 8A D3 56 46 73 63 A8 86 37 B9 DA 2D 42 CF 89 AA 63 EA FA 9F C1 75 AE 7A 8B F3 7D B2 24 74 B8 81 8B 78 8E BE 0C 11 48 13 96 DE F1 32 18 61 14 4D B9 4D 76 1C 44 23 F6 CA 81 99 61 C2 B0 FA 56 75 32 30 81 AD 5A E1 4C 54 0F C4 90 E5 53 C7 7E 72 75 8B 3A 72 A0 A0 DA 4F 5E 07 FA 16 E9 7E 9E D8 85 A8 CA B9 92 E4 4B 6C 4B 45 C8 4B 66 80 AF 53 71 2E E7 62 98 E4 08 A0 34 46 74 92 BB 80 94 A2 51 82 BC 0C 5B AB 66 EC 9E CA D9 84 37 8C 89 3F 9D 0A DD 39 53 94 44 B5 67 BD 57 0C AD 26 B9 FC E5 5F FA A2 C3 AA F9 04 66 F7 97 E8 61 F0 5C 2E F8 92 AA 3D 59 19 00 98 20 D2 79 A1 70 57 1D D3 1D 85 DF BD ED 02 47 E7 95 34 11 D8 0C 3D 2D 26 0A A1 38 91 52 C4 62 E8 38 DC 05 73 1D 8D C0 BB 36 51 63 F9 6C 76 28 F9 4F 2A 68 8A C5 4C 3C EE 95 B0 34 E7 7E
16:26:54
TX: 7E A0 07 03 61 D1 7F 26 7E
16:26:54
RX: 7E A1 FD 61 03 DC 4B BB 9C 7E 09 0C F2 D2 D8 47 18 5E 5D DD 62 33 8B 91 C9 DE A1 8C 52 28 DF EC A7 9F 90 B7 F6 6B A8 BC D0 A8 25 22 80 42 6E 78 BC B6 9E DF 04 9F 51 2D 71 5D 00 AA 3F BC 34 74 0D 83 F6 0B F7 32 69 25 77 82 69 D0 2E 30 A5 C4 DB D4 CF 91 DB 52 1D BB EF EF F1 DA D9 7A 93 8A C2 27 2F 39 0E BE 2B 74 55 D1 17 80 63 E7 2D 4C 67 28 58 2E 99 7C E0 59 A0 69 CC 0D 0A BD FD 9A E8 59 B1 2E 63 8A 7E 6A 26 12 19 F4 9D BE 63 C1 09 B8 F8 7B D7 BD C0 9E 8D 5E 56 EF E4 40 81 A3 C9 37 72 DE 6F 72 22 60 1F E3 BC D8 5B D7 A2 0C 41 BB 2D 86 64 2F 33 54 76 00 01 C3 C2 0C A0 F5 E4 92 AC 1D 17 71 EB B1 84 27 A3 00 76 9E 6A 23 5D 68 78 40 26 4E BE FA DF 2F 60 CF C2 85 E5 9D 2A 5A 11 0C 89 08 07 A9 04 42 D4 A7 C1 84 54 A5 FF DE 14 3E 07 34 4B 89 70 F8 00 06 10 88 A0 06 5F 3B 40 B0 25 41 42 7F F4 2B 8D DE 67 F9 2E 5B 2D 73 EA BE CE 6E 5B 3D 4F 9C 29 85 58 E3 0E 1D 2C B4 CD F8 B6 2B 09 38 4F 97 12 05 98 AB 78 29 E6 F5 D6 81 83 82 B7 0E E9 1C DB 50 97 71 31 0E 67 F6 0A 60 E5 70 DD BF 92 AA F7 11 1D 53 D2 0D DF F3 FA 47 66 16 9B 74 C5 99 F3 4D C3 1D 95 62 33 89 9C EB 1E 2D 47 35 9A 41 34 31 76 C2 FB 22 2F CD DD 98 68 09 FF C1 E6 1F 93 3B F8 E5 17 45 E9 B5 E8 8E 01 0C D9 CE 2E 89 93 B9 03 B3 7F 6A DA EB F5 B6 4D 36 A1 E6 BD F3 4A 14 EF 1C FF A5 82 10 2C 4F 7E 61 25 2F 52 4F FB C1 FA 68 1D EB 33 03 7E AE CF AE 29 DA 6D 4C 84 6E EB 10 E9 1E 58 B0 8B 49 A2 B1 B3 6A B9 E2 CE B0 31 9A BD 8E 64 CE 72 E3 7C E3 B3 18 28 B1 25 3C 23 F8 3A 17 6F 02 F2 E7 FF DB 87 53 A3 BB 7C 65 EF 95 A1 A9 58 33 EB 9B 3B 4B B2 A8 70 C9 D8 E1 A4 0D 7E
16:26:54
TX: 7E A0 26 03 61 FC 70 4F E6 E6 00 C8 18 30 00 00 00 7A 93 50 A4 CB CD 94 07 0B 21 0B 88 94 7C 59 0E 67 A5 6E 24 1B 95 7E
16:26:55
RX: 7E AA 4C 61 03 FE 90 83 E6 E7 00 CC 82 04 30 30 00 04 0A F4 97 EA 70 F8 FD 4C 96 69 85 65 7B 1C 18 A2 93 B9 40 68 0C A4 B8 60 95 9D 6A 3D 11 FE 3E 08 FB D9 78 FF 8A 1D F8 C7 4C 12 C3 E2 C8 6D EE 3F EE 99 91 BC 5E 54 04 09 34 79 AF 4B 37 0B 18 85 5C 2F B3 36 1D 25 EA E8 61 F0 78 0B CB FB AA 4E 29 82 E8 AA 69 9E EE 43 6C F2 40 75 6F 8F CA D6 FA CE D9 89 92 BC 30 89 94 E1 C7 8B 03 49 7F 3B 44 A8 C3 58 71 98 53 A9 23 BE DA 89 B8 3A BE 0A D0 B8 27 D0 4F 06 14 E0 28 84 D4 36 64 A0 3A 00 A3 E4 D4 23 A2 45 DC DC CE E3 A6 35 30 A1 AE DF 75 FF 03 F3 17 00 83 E4 18 45 F6 6F EF 19 B6 F0 94 02 AD 4F 7F 9D 79 E4 C8 F5 56 54 45 61 8A A7 6F 08 CE A6 5E DB BD E9 3A 5E 07 BC 7E 3B 25 21 11 74 A8 D1 02 BB 4E 8A F4 D9 A3 56 AF 59 62 21 8A 96 9C D4 4E 47 7B 28 D6 2C 16 1F 39 29 97 1A 57 67 93 53 9C F4 0C B7 D0 34 24 5E 49 EC 4D DC 6F DD 2B 20 58 D2 21 01 DE 36 6C B9 E5 41 A9 DE E8 6E 7B 25 80 10 2B 7C 4D C9 E9 07 F6 D1 3C F8 D3 71 83 AA A0 8A CB 63 B1 CB D9 77 CF 42 E1 00 07 7E 12 15 0E E3 C7 34 83 E2 1C 3D DA 48 B5 0E EF 16 67 E3 D6 C9 E1 EB C8 38 05 22 A3 EE EE 33 24 7D 4C F2 7B 4E 2F 73 20 B1 61 49 25 BD 74 35 F8 FE 59 57 58 C2 22 D1 CA 68 E8 C6 99 C7 DC 09 0E 6F 8D 01 76 19 FD 16 DC 1B 42 60 27 8E B4 04 1E 66 11 D4 08 EB 66 BB 2B 09 14 A3 A1 C2 B8 74 7C FE 21 BB 15 48 94 44 19 A9 43 41 4D C8 37 70 99 23 6B 2C AB 84 F4 4C C9 44 AC 76 44 86 E7 28 64 52 D3 5E ED 0F 27 89 78 0C 51 AC DA F8 55 29 C9 E0 D6 10 5A 05 13 06 E4 E5 FD 02 B4 5A 81 F5 0E E0 89 AF F9 E0 30 57 6E 18 69 D5 43 5B 8D 20 52 9C 87 2B 52 7D 89 3E 60 33 32 9E 08 5F 45 FC BE 8F 82 26 51 AE 2C 75 EA E5 3E 9B 33 A2 F8 AA 3F 58 77 46 8F 96 77 E2 36 56 5F F5 38 5C 9D 03 DB 95 4E FA 57 90 66 B7 D7 ED 4E 92 2C 21 6D AF 4F 38 63 5D 79 9B C5 94 91 DE EB 83 3B D4 BD 83 09 BE AC 16 09 39 7A DD 80 FB 47 7E
16:26:55
TX: 7E A0 07 03 61 11 73 E0 7E
16:26:56
RX: 7E A1 FD 61 03 F0 25 50 0F AA 05 DD 5F 38 5D F2 BA 9A 0E 38 68 41 2C 4A 10 4F E5 A1 8A A0 51 5A FD 09 3F A5 5D D1 3A D7 84 7F 8B 08 8E 1F BF 4B C8 25 B5 2F 69 94 E8 80 37 7E C0 AF C2 4E 88 CA 49 BB 13 C8 3D 30 C8 24 7A C8 31 6B 89 F6 D8 1E FD 55 F9 F3 24 9F 4C 02 27 20 BB C4 B8 10 23 24 B1 59 F9 1A 15 A1 98 33 49 FE 52 48 16 66 25 C1 3E CE AF C5 88 68 A1 94 E0 75 7A 83 8F F8 84 1A 16 0E C8 C4 9D A7 31 53 DC FC 62 B5 94 D1 DE D1 D5 6D 85 91 1D 63 21 AF BB F2 CB 37 7D 2F E9 0B 8E 7C A2 B7 68 85 BC 8E 37 4D CE 90 62 11 A8 AD E7 3F EF 3C 01 4C E8 11 67 7B B1 45 F1 66 4B 04 7A 1C B4 08 BB 1D C6 BF 81 02 F7 6E 38 9C 0A 9C 62 20 0C 02 F4 50 F2 83 C6 1D 97 33 ED 5E B8 64 D4 80 55 23 68 1F D2 0A 81 E3 F9 14 33 20 94 25 4C F8 3C 19 44 17 9A BF 8A 07 BB 19 E2 85 94 93 17 98 89 1E CC FD BD 17 42 86 F0 B8 3D 62 4C 5C 28 F6 42 83 55 C8 C9 31 B1 2D 03 CC FF AF 17 46 22 CD C2 C4 ED 18 98 ED AE B1 8E C4 04 4C 66 C6 6B 22 27 9B B7 74 EA A3 BC CB 5D E5 2B CD 25 5D 4C 06 94 D7 4F 8C 91 D1 3D 12 65 91 62 D8 AF D7 84 3A 76 77 12 83 F4 1A C1 4F 4C D3 FD 59 E4 62 58 8A 8F DB 3D 64 3E 1D E6 B5 83 19 DE BE E8 0A 72 C7 6B BC 1B E2 05 08 80 8E C8 00 E7 15 CF 8E 16 32 77 14 3A 82 97 DA B1 1F 74 BC 4E 02 B9 8A BD 9A 91 E9 92 58 AB 1B 36 65 60 04 E7 AC 10 E6 2B 96 6A 08 CA 48 5B 47 9C 7E CC 12 48 E8 5A 4A FB F9 E3 65 71 C7 CA 5E 48 C1 E5 C7 9E 3F B3 DF C0 18 16 F9 6A 38 F6 07 28 DE 82 D9 CB 20 B2 39 50 FF 37 70 06 2E 5A 29 AA 65 E8 54 C0 7D AF B1 6D 2F 36 F7 E9 8B CD 6F E0 E6 F4 BE D0 A9 4E 35 6F E0 1F A7 31 39 EE 03 F2 07 72 FF F2 FF 7E
16:26:56
TX: 7E A0 26 03 61 3E 6E AA E6 E6 00 C8 18 30 00 00 00 7B A9 11 96 AA B5 06 13 68 8F 5C EF 90 20 64 E9 36 E3 F2 17 14 25 7E
16:26:56
RX: 7E A0 63 61 03 12 F0 DF E6 E7 00 CC 55 30 00 04 0A F5 5F 03 85 FB FC 1C 08 D0 5A F8 21 56 B3 FC 5F 59 EF 2E 4E F4 24 3D EE 61 80 40 EB BC 55 C2 30 B2 4B 2F 05 76 A5 6F CA F8 06 09 70 D4 5F E6 6A E8 F5 A1 28 97 B4 FB A8 8B B7 73 6A 5C 3C DF B8 4B 08 3B 26 20 33 8F C7 C5 7C DB 90 0D 0C 5C F4 7F 3E F2 7E
16:26:56 Read object type ProfileGeneric index: 7
TX: 7E A0 2C 03 61 50 B8 FC E6 E6 00 C8 1E 30 00 00 00 7C F4 96 18 FD 5E 30 2E F5 57 81 0F 57 63 0E 98 94 13 FB AD E7 1E 7A 1E 4C 86 2B B4 7E
16:26:57
RX: 7E A0 28 61 03 34 66 4D E6 E7 00 CC 1A 30 00 04 0A F6 AD 10 B6 BA CD 4D F7 5E 98 77 09 91 00 68 02 D1 13 A1 8F 00 94 53 78 7E
16:26:57 Read object type ProfileGeneric index: 8
TX: 7E A0 2C 03 61 72 A8 FE E6 E6 00 C8 1E 30 00 00 00 7D 8E 65 F9 BF 49 28 74 46 4B 34 2C 8F C5 A7 CC DE 45 57 40 9C 28 8B 8D 01 B4 3C BE 7E
16:26:57
RX: 7E A0 28 61 03 56 72 0D E6 E7 00 CC 1A 30 00 04 0A F7 D8 BC 08 66 54 A7 62 57 46 03 BF A0 69 2A 1B 36 B0 CE D5 93 F0 F2 75 7E
3 years 6 months ago
Hi, This is fixed for…
This is fixed for version 2.0.4. Let me know if you have any problems.
sachinar007
In reply to Hi, This is fixed for… by Kurumi
Hi sir, very good morning…
Hi sir, very good morning.
NOTE : Manufacturer(Indian Standard)
As We have imported the DLMS code from current version 2.0.4 into our application, it's having a problem opening the connection in "US" authentication, it Says "Connection is permanently rejected The authentication mechanism name is not recognized."
In the previous version, it was working properly (Vesion : 2.0.3).
//Not related to topic, just a additional note.
I have added below code to "Signing.java" from other enums which I think it should be there in future releases for use.
public int getValue() {
return this.ordinal();
public static Signing forValue(final int value) {
Signing ret = values()[value];
if (ret == null) {
throw new IllegalArgumentException("Invalid signing enum value.");
return ret;
In reply to Hi sir, very good morning… by sachinar007
Hi, I did try to connect…
I did try to connect with "US" and it worked without problems. Can you connect with the Client example?
sachinar007
In reply to Hi, I did try to connect… by Kurumi
Hi Sir, Sorry for the…
Hi Sir,
Sorry for the delayed response but Thankyou as you suggested I tried Client Example also still it was not worked initially.
But after some debugging, I found that Selecting "US" Authentication was still providing "NONE" as the type because of an Exception at another place while porting the code.
But now all is working fine. readRowsByRange is also working properly Sir.
Thank you for your support.
I am attaching the issue caused by an exception from our side.
sachinar007
In the previous code I had…
In the previous code I had explained that even with Authentication "US", we were getting "NONE" as a type. I found something which is actually related to this issue and not actually our Exceptions.
This is just a suggestion as In MainActivity.java class when we call loadSettings().
try {
mDevice.setAuthentication(new GXAuthentication(s.getString("authentication", "None")));
} catch (Exception ex) {
//Old way...
mDevice.setAuthentication(new GXAuthentication(Authentication.forValue(s.getInt("authentication", 0)).toString()));
in above >>> new GXAuthentication(....<<< returns "US" Authentication name along with "NONE" as type.
So when user user goes on MeterSetting Page there he/she can see the Authentication as what was selected but it will have different type. SO when we go to the main page to read...while establishing a connection it gets the wrong Authentication type too.
If user clicks and select AUthentication again then there is no issue because there we are loading manufacturer's Authentication type list, so we get proper Authentication name and type.
My only Suggestion is for Client Application is, that you replace this code
try {
//Old way...
WITH
if (s.contains("authentication")) {
//Setting UP Authentication based on Actual Manufacturer
GXManufacturer man = getManufacturer();
assert man != null;
List<GXAuthentication> values = new ArrayList<>(man.getSettings());
int selected = -1;
int pos = 0;
String selectedItem = s.getString("authentication", "None");
for (GXAuthentication it : values) {
//Get selected item.
if (it.toString().compareTo(selectedItem) == 0) {
selected = pos;
++pos;
mDevice.setAuthentication(values.get(selected));
} else {
//Old way...
OR any short version of it as it will return proper Selected Authentication name and type from the selected manufacturer.
In reply to In the previous code I had… by sachinar007
Hi, The authentication name…
The authentication name is just a description string for the user. It's not used anywhere or means anything.
The example is updated and the authentication level is read from the manufacturer settings as you proposed. Get the latest version from GitHub.
sachinar007
In reply to Hi, The authentication name… by Kurumi
Ok, Thankyou for accepting…
Ok, Thankyou for accepting the suggestion.
