  2. Firmware Upgrade
Firmware upgrade
By kevin jose minj , 21 March, 2023
How to upgrade firmware through python code?
file = open("firmware_iskra.bin", "rb")
reply = GXReplyData()
ImageTransfer = GXDLMSImageTransfer()
imageBlockSize = self.read(ImageTransfer, 2)
fw_filename = "firmware_iskra.bin"
imageIdentifier = "firmware_iskra"
forImageSize = int(os.path.getsize(fw_filename))
data=ImageTransfer.imageTransferInitiate(self.client,imageIdentifier,forImageSize)
init_val = self.readDataBlock(data, reply)
ImageTransfer.imageBlockValue = file.read()
ImageTransfer.imageBlockCount = None
frames = ImageTransfer.imageBlockTransfer(self.client,
ImageTransfer.imageBlockValue, ImageTransfer.imageBlockCount)
reader.readDataBlock(frames,reply)
This code return access error: unknown error
What is the issue causing with this I tried in GuruxDLMSDirector its working fine while select the file and click update
3 years 4 months ago
Hi, Check first that the…
Check first that the image identifier is correct. Some meters accept only specific names.
Can you transfer all the blocks for the meter or are you getting the exception right after imageTransferInitiate?
kevin jose minj
In reply to Hi, Check first that the… by Kurumi
data=ImageTransfer…
when I am try to read this data issue is occuring and I passed active firmware identifier what I got from GuruxDLMS director now its showing
Access Error : Device reports a unmatched type.
In reply to data=ImageTransfer… by kevin jose minj
Hi, Check the image size…
Check the image size that that is correct. What image identifier you was using in GuruxDLMSDirector? Use the same.
kevin jose minj
In reply to Hi, Check the image size… by Kurumi
same error Access Error :…
same error
identifier and image size is correct
In reply to same error Access Error :… by kevin jose minj
Hi, Our clients can update…
Our clients can update Iskraemeco meters, but the firmware identifier is not "firmware_iskra".
You need to verify that from the meter vendor.
kevin jose minj
In reply to Hi, Our clients can update… by Kurumi
Is there any way to check…
Is there any way to check the firmware identifier with gurux director?
In reply to Is there any way to check… by kevin jose minj
Hi, No. The meter doesn't…
No. The meter doesn't tell it and meter manufacturers are using different names for it.
kevin jose minj
3 years 1 month ago
Hi Mikko, While I am…
While I am updating firmware I am getting the error below
byte must be in range(0, 256)
In this line of code
frames = ImageTransfer.imageBlockTransfer(self.client,ImageTransfer.imageBlockValue, ImageTransfer.imageBlockCount)
kevin jose minj
3 years 1 month ago
Any updates regarding in…
Any updates regarding in this?
