  3. DLMS Device Response Is With Different Target and Source Address
DLMS device response is with different target and source address
By labasvakaras , 14 March, 2023
Sending request with Source Address 145, i get response with target address 16 and source address 16401. Is this a problem with device?
TX: 7E A0 08 02 23 21 93 BD 64 7E
RX: 7E A0 23 21 00 02 00 23 73 F6 C5 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
I am using Gurux DLMS C library.
3 years 8 months ago
Hi, Your meter is using four…
Your meter is using four bytes, but it's possible to use logical and server addresses with two bytes.
Can you communicate without problems with the meter?
labasvakaras
With DLMS director I can…
With DLMS director I can communicate with device, but I can't reach my device with Gurux DLMS C library. Is it possible to solve this issue by myself (without patches)?
Probably there is no support for DLMS protocol version 2?
Hi, ANSI C client is…
ANSI C client is improved so it can handle this. Get the latest version.
labasvakaras
3 years 7 months ago
hi, I updated to latest…
hi, I updated to latest version and now when I want to disconnect, i am sending multiple disconnect payloads. Is this intended?
Server dump:
Connected.
TX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 04 00 00 07 E0 A6 7E
RX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2A 00 00 FF 02 00 12 80 7E
TX: 7E A0 22 21 03 52 8E 91 E6 E7 00 C4 01 C1 00 09 10 47 52 58 30 30 30 30 30 30 30 31 32 33 34 35 36 8C 86 7E
RX: 7E A0 11 03 21 54 87 3B E6 E6 00 62 03 80 01 00 BD 9B 7E
Disconnected.
TX: 7E A0 23 21 03 74 01 C9 E6 E7 00 63 11 80 01 00 BE 0F 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 04 00 00 07 92 4A 7E
RX: 7E A0 07 03 21 53 03 C7 7E
Disconnected.
TX: 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
Hi, Your meter is using 4…
It's sending the release and then disconnect. That is normal.
