  3. Cannot Read Association View
Cannot read association view
By DenisMalakhov , 3 March, 2023
Hello, I tried to run example from your github, but the exception occurred. In the code below, the connection was successfully established, but when trying to read the association, it immediately throws an exception. But with GXDLMSDirector association was read successfully.
public void ReadAll(string outputFile)
try
InitializeConnection(); // OK
if (GetAssociationView(outputFile)) // "Service not allowed"-exception.
GetScalersAndUnits();
GetProfileGenericColumns();
GetReadOut();
GetProfileGenerics();
if (outputFile != null)
try
Client.Objects.Save(outputFile, new GXXmlWriterSettings() { UseMeterTime = true, IgnoreDefaultValues = false });
catch (Exception)
//It's OK if this fails.
finally
Close();
There is log from console:
Standard: DLMS
Send SNRM request.7E A0 0A 00 02 FE FF 61 93 BB C4 7E
TX: 10:40:34 7E A0 0A 00 02 FE FF 61 93 BB C4 7E
RX: 10:40:35 7E A0 23 61 00 02 10 3D 73 33 4D 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
Parsing UA reply.81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01
Parsing UA reply succeeded.
Send AARQ request
TX: 10:40:35 7E A0 4F 00 02 FE FF 61 10 8D 45 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 14 5C 76 33 40 44 10 5B 2C 15 61 6A 1D 79 47 29 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 36 83 7E
RX: 10:40:37 7E A0 5B 61 00 02 10 3D 30 0C F2 E6 E7 00 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 9D 02 BE 46 C6 59 D4 DE D9 B7 46 20 0C CD DE 34 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1C 1D 00 80 00 07 2E 40 7E
Parsing AARE reply61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 9D 02 BE 46 C6 59 D4 DE D9 B7 46 20 0C CD DE 34 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1C 1D 00 80 00 07
Conformance: BlockTransferWithGetOrRead, BlockTransferWithSetOrWrite, BlockTransferWithAction, Get, Set, SelectiveAccess, Action
Parsing AARE reply succeeded.
TX: 10:40:43 7E A0 1C 00 02 FE FF 61 32 3C 9D E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
RX: 10:40:44 7E A0 12 61 00 02 10 3D 52 27 34 E6 E7 00 D8 01 01 3C 43 7E
Disconnecting from the meter.
TX: 10:40:44 7E A0 0A 00 02 FE FF 61 53 B7 02 7E
RX: 10:40:45 7E A0 0A 61 00 02 10 3D 73 89 6F 7E
Exception response. "Service not allowed"-exception. Operation not possible
3 years 6 months ago
Hi, It seems like your meter…
It seems like your meter doesn't implement an association view for this association. Can you connect without authentication (Authentication is None) and read the association view?
Association view is mandatory in DLMS meters, but some DLMS sub-standards (e.g. India and Italy) define used objects and some meter doesn't implement the association view because of that.
If your meter doesn't implement the association view you must know what you want to read and add those objects by yourself.
