  3. How To Set Logical Server Address On Client?
How to set logical server address on client?
By bayasgalan , 5 November, 2020
I'm working on driver software as client for Wasion electric meter. But meter's logical server address is 1, but I can't find logical server address setting in dlms.c file. is it not implemented yet? how to add logical server address part in hdlc address?
6 years ago
Logical server address 1 is the default value, but you can change it with cl_init method.
cl_init(&settings,
// Is used Logican Name or Short Name referencing.
1,
//Client ID
16,
//Server ID
1,
//Authentication Level.
DLMS_AUTHENTICATION_NONE,
//Password
NULL,
// Is used HDLC or COSEM transport layers for IPv4 networks (IEC 62056-47)
DLMS_INTERFACE_TYPE_HDLC);
You can get more information from here:
http://www.gurux.fi/Gurux.DLMS.Client
bayasgalan
6 years ago
The meter's physical server
The meter's physical server address is 129 and logical server address is 1. But I can only set physical server address in cl_init. In GX dlms director, I can set logical server address as attached picture.
When I set logical server address to 1, the SNRM request is like 7E A0 0A 00 02 02 03 03 93 D6 5B 7E and meter responds.
When i set logical server address to 0, the SNRM request is: 7E A0 08 02 03 03 93 05 77 7E and meter is not responding because Meter's logical server address is 1.
6 years ago
There is no GetServerAddress for ANSI C. I'll add that to the worklist. In the meantime, you can use value: 0x4081. It will do the trick.
bayasgalan
6 years ago
i've tried and it's working.
Thanks a lot
6 years ago
cl_getServerAddress method is added. You can use it to get the server address from the physical and logical address.
Rui Costa
3 years 8 months ago
Hi, how did you arrive at…
how did you arrive at that number (0x4081)?
I am using meter ACE6000 and my phisical adress server is 7F. The logic is 1. Using the example, what number should I put?
Best regards,
Rui Costa
