  3. Read-Write Denied But I Get These Permissions
Read-Write denied but I get these permissions
By nick32 , 1 February, 2023
I have connected to my meter with these credential:
client address:17
server address: 1
and I got these permissions:
IsAuthenticationRequired: false
Proposed conformance:
[GENERAL_PROTECTION, GET, SET, BLOCK_TRANSFER_WITH_ACTION, BLOCK_TRANSFER_WITH_SET_OR_WRITE, DELTA_VALUE_ENCODING, SELECTIVE_ACCESS, ACTION, MULTIPLE_REFERENCES, BLOCK_TRANSFER_WITH_GET_OR_READ, ACCESS]
Negotiated conformance:
[GET, SET, BLOCK_TRANSFER_WITH_SET_OR_WRITE, ACTION, SELECTIVE_ACCESS, MULTIPLE_REFERENCES, BLOCK_TRANSFER_WITH_GET_OR_READ]
MaxReceivePDUSize: 243
I understand that i am able to write the meter, isn't it?
But, when I try to connect/disconnect the charge using the object GXDLMSDisconnectControl, I get this error:
Exception in thread "main" gurux.dlms.GXDLMSException: Access Error : Device reports Read-Write denied.
Do you have any idea why is it happen ?
3 years 7 months ago
Hi, It might be that you can…
It might be that you can't access the GXDLMSDisconnectControl with current client settings.
Try to connect with GXDLMSDirector. Can you see the Disconnect Control in the object tree? Can you invoke it?
nick32
In reply to Hi, It might be that you can… by Kurumi
Hi Mikko, yes, I can seee de…
yes, I can seee de disconnect control tree but I can not change the state of charge using GXDLMSDirector.
I was able connect to the meter using manufacture software, and I just have Read-Write permission to the attribute ControlMode.
Can you explain to me how it works ? Because, I use this code to connect the charge.
GXDLMSDisconnectControl disconnectControl = new GXDLMSDisconnectControl(OBISObjectAddress.DISCONNECT_CONTROL);
byte[][] write;
disconnectControl.setControlState(ControlState.CONNECTED);
replyData.clear();
write = client.write(disconnectControl, 4);
readDataBlock(write, replyData);
But, when I try to disconnect with this code, it does not work.
byte[][] write;
disconnectControl.setControlState(ControlState.DISCONNECTED);
replyData.clear();
Thank for your help.
