  3. Timestamp
Timestamp
By kevin jose minj , 6 January, 2023
When I am reading the billing profile date the timestamp is getting as hexadecimal is there any way to convert it into readable form?
This is the output I am getting
07 E7 01 01 04 00 00 00 FF FE B6 FF | 0 | 402878 | 394856 | 1926 | 3780 | 2316 | 0 | 397033 | 388498 | 2062 | 4141 | 2331 | 0 | 0 | 05:30:00:000000 | 0 | 05:30:00:000000 | 0 | 05:30:00:000000 | 0 | 05:30:00:000000 | 0 | 05:30:00:000000 | 0 | 05:30:00:000000 | 10 | 12/26/22 11:00:00 | 10 | 12/26/22 11:00:00 | 5 | 12/23/22 16:30:00 | 5 | 12/23/22 17:30:00 | 0 | 05:30:00:000000 | 0 | 05:30:00:000000 | 1699 | 0 | 0"
3 years 10 months ago
If you have read the capture objects (attribute index #3) the date time should be converted automatically. when you read the buffer
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
