  3. Example Like Crystal.xml
Example like crystal.xml
By amartinez10 , 21 November, 2022
I am trying to simulate a real meter with DLMS.Simulator.
The fact is, I don't have any meter to take data from it and then load in the Simulator. And in the files there is only crystal.xml
Anybody has another files to use in the simulator?
Thanks in advance
4 years ago
I can add another example. What kind of meter do you need or do you have a specific model in mind?
amartinez10
4 years ago
I need Itron SL7000.
Thank you Mikko
4 years ago
SL7000 is causing some problems to simulate. I can generate the template, but reading some profile generates (historical data) doesn't work like in SL7000. Some SL7000 profile generics are implemented in a custom way. Current values work without problems.
amartinez10
4 years ago
Hello Mikko,
Hello Mikko,
it's ok, don't worry, I just need to read current values.
Thanks in advance.
amartinez10
4 years ago
Mikko,
Mikko,
if SL7000 is not the best option for you because of the problems, I also could do the test with Landis&Gyr E650, I don't know if it is better for you.
