  3. Execute Time
execute time
By fon Luck , 16 May, 2022
Hi!
The srv_run() function in file server.c calculates the output parameter "next" as the current time plus the timeout of one of the events. If the first timeout is longer than the others, the next execution will be too late for other events.
4 years 2 months ago
svr_run will check the next execution time and it's saved to the next if it's smaller than the current execution time. It's initialized 0xFFFFFFFF in the begin of svr_run. Can you share what kind of executions you have added so this can be tested with your settings?
fon Luck
Hello!
Hello!
You are right. Sorry to bother you.
No problems. It's good to ask if you have any doubts.
  • NithnCXPiBJHVG…
  • utkarsh9460
  • cWYHszETmudslY…
  • Aij
  • vondamc1
