  3. GXDateTime.toUnixTime For Python
GXDateTime.toUnixTime for Python
By Lotusv , 26 April, 2022
When using the function GXDateTime.toUnixTime
GXDT = GXDLMSClient.changeType(Var1, DataType.DATETIME)
DT = GXDT.toUnixTime(GXDT)
Got an error in the module:
"GXDateTime.toUnixTime isinstance() arg 2 must be a type or tuple of types"
I propose to change
isinstance(value, (datetime))
on
isinstance(value, type(datetime))
@classmethod
def toUnixTime(cls, value):
___if isinstance(value, type(datetime)):
______return value.utctimetuple()
___if isinstance(value, (GXDateTime)):
______return value.value.utctimetuple()
___return int(value.value / 1000)
And check the reverse conversion. I haven't used or tested it...
4 years 3 months ago
You are right. There is an issue on toUnixTime. It should be like this:
if isinstance(value, (datetime.datetime)):
This is fixed and the new version is released today.
  • HilipLot
  • NithnCXPiBJHVG…
  • utkarsh9460
  • cWYHszETmudslY…
  • Aij
