  3. Dlms.c Server. Casting Target To Uint16_t
dlms.c server. Casting target to uint16_t
By fon Luck , 13 April, 2022
Hello!
In file dlms.c function dlms_check Hdlc Address() save target address into setting->server Address.
But, target address converted to uint16_t, therefore upper address is lost and is Target() can't check it.
I found this closed issue: http://www.gurux.fi/node/15797
4 years 5 months ago
The maximum size of the HDLC physical address is uint16_t, but because there is no harm this cast is removed.
https://www.gurux.fi/dlmsaddress
Thank you for pointing this out. Get the latest version.
