  3. Bug In Gateway Protocol With HighGMAC
bug in gateway protocol with HighGMAC
By ali_bahal , 11 April, 2022
Hi. when I want to connect to meter with "Gateway" protocol with "HighGMAC" security and "EncryptionAuthentication" like below command line parameter :
-h *.*.*.* -p 4059 -iWRAPPER -c 1 -a HighGMAC -P 12345678 -C AuthenticationEncryption -T 4541410550A97D18 -A D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF -B 000102030405060708090A0B0C0D0E0F -D C6F858068DC7150F6828E9B56D700D04 -v 0.0.43.1.0.255 -t Verbose
there is bug in authentication packet and gurux does not use "Gateway headers" in this packet , so the connection can't be established.
here is the packets :
Send AARQ request.
TX: 00 01 00 01 00 01 00 75 E6 00 02 1D B8 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 45 41 41 05 50 A9 7D 18 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 13 60 3A 79 63 0D 15 4A 1F 46 36 73 2A 27 4D 66 BE 34 04 32 21 30 30 00 00 00 33 AE 84 13 D0 43 FE EE FE 6E 97 2F 99 5D D4 8B 84 80 5B 4E 91 E2 F8 B0 C2 22 FE AB 5B 74 A5 B2 FF 30 ED AB 90 8C 1A 38 55 81 E2 EF
RX: 00 01 00 01 00 01 00 70 E7 00 02 1D B8 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 41 41 05 50 A9 7D 18 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 74 4D 69 2C 6D 4B 67 4B 62 39 60 3B 79 2E 2D 45 BE 23 04 21 28 1F 30 00 00 00 31 29 5B 87 32 2A 2F 02 68 C5 58 28 38 D2 81 97 2F FA DF 5C 16 06 26 E7 58 71 43
Authenticating.
TX: 00 01 00 01 00 01 00 38 CB 36 30 00 00 00 34 6B 7A 69 9D 6A 2D 17 F0 80 50 09 89 E6 E8 18 2A DA 75 00 C3 78 87 68 6E BF 5B 51 69 B2 34 5A 15 38 20 4E EB FE 31 64 D6 83 16 D6 D6 EA 01 C0 C3 0D
Data send failed. Try to resend 1/2
I use c# version. thank you
4 years 7 months ago
You are right on this. This is under the work. I need to think about how and when this can be released.
ali_bahal
sorry , do you think it can
sorry , do you think it can be released in a month ?
We are making a custom release for this and it's released at the end of this month. I do not know the exact day yet, but you can ask after next week if you are interested.
ali_bahal
4 years 6 months ago
hi, I want to know if you
hi, I want to know if you have released any version about this problem or not?
This is fixed for C#, but not released yet. I can't say the exact day yet. Let me know if you are using some other programming language as C# and it's added for it as well.
ali_bahal
we also use c version, but
we also use c version, but our main requirement is c# version. I'll appreciate if you can release it soon.
thank you
Our clients are keeping us busy, but we try to release this in the following weeks.
ali_bahal
Thank you very much. I'll
Thank you very much. I'll check it next week again
ali_bahal
Hi, do you think you can
Hi, do you think you can release a fix for this problem this week?
The new version from C# is on the Github. Add -G 0:0x1DB8 parameter for the command line to use gateway protocol.
ali_bahal
thank you , I'll test it and
thank you , I'll test it and let you know the result
