  3. Fault To Connect Meter By Gateway
Fault to connect meter by gateway
Profile picture for user mahsen
By mahsen , 10 April, 2022
Hi Dear,
im used DLMSDirector.exe,
i want connect to meter by address 1654 by gateway and secured connections,
TX: 00 01 00 01 00 01 00 64 E6 00 02 16 54 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 45 41 41 07 00 10 3F 0C 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 6A 6E 39 0F 27 25 1E 2E 59 0F 69 2A 30 68 45 0F BE 23 04 21 21 1F 30 00 00 0D 32 99 1A EB 28 21 09 2C 01 CB B6 64 CD 66 44 FB AF 1C 4C 14 D6 5A 11 90 0D CB 47
RX: 00 01 00 01 00 01 00 68 E7 00 02 16 54 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 41 41 07 00 10 3F 0C 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 4F 17 44 6D 7B 13 E8 64 BE 23 04 21 28 1F 30 00 00 01 7C 10 41 51 5D 87 83 10 AE 73 61 2D B2 A9 04 AB A2 ED 01 B4 C5 45 35 4E 31 6C F8
TX: 00 01 00 01 00 01 00 38 CB 36 30 00 00 0D 33 92 3C B1 05 EB 81 36 DE 19 2B 49 A0 4D 03 9F DE 8E 1F CA FF F0 76 52 F5 5A 31 F1 57 D2 4E 32 22 F1 29 D8 DB 78 F4 E4 5C B0 C4 63 59 27 D4 D6 0B C9
16:21:24 Data send failed. Try to resend 1/3
16:21:29 Data send failed. Try to resend 2/3
16:21:34 Failed to receive reply from the device in given time.
in second TX why no address "0x16 0x54" and "0xE6 0x00" ?
Can you guide me ?
Mahsen.
4 years 7 months ago
Hi Mahsen,
Hi Mahsen,
It seems that there is an issue with gateway protocol when ciphered data is used.
The gateway protocol is not added when you are using a secured connection.
I need to think should make a special release from this issue so it can be released faster.
mahsen
4 years 6 months ago
Hi Dear,
Hi Dear,
I am waiting for your solution.
Mahsen.
Hi Mahsen,
Hi Mahsen,
I believe that the new version can be released the next week.
Hi Mahsen,
Hi Mahsen,
The new version where this is fixed is on the Github and the new version from GXDLMSDirector is released today.
dsoler
1 year 10 months ago
Hi there! I'm facing the…
Hi there! I'm facing the same issue. The gateway is sent only on the first frame. was it solved? thanks!
