  3. Network Parameters For Monitoring
Network parameters for monitoring
By tagmout , 2 March, 2022
I hope you feel great
Can you please tell us , what are the network parameters that we can monitoring in the meters and which protocols to use .
BR
4 years 6 months ago
DLMS meters are using DLMS protocol, but framing depends on what communication channel they are using. It can be an example TCP/IP, GPRS or M-Bus.
tagmout
Yes , sure .
Yes , sure .
For example , whene we use gprs, how we can get the baudrate of transmission , the loss packets , the disponibility of the modem ect ...
BR
That depends on the meter. You can check if a GSM diagnostic is implemented for the meter.
http://gurux.fi/Gurux.DLMS.Objects.GXDLMSGSMDiagnostic
Some manufacturers are saving this information for data or register objects. You need to ask this from the meter vendor if that information is not available on the documentation of the meter.
