  3. Upgrade The Firmware In Python Code
Upgrade The Firmware in Python Code
By Jinay Sharma , 7 March, 2022
How can i upgrade the firmware in python code.
I am using Rpi Board. I am using Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/
Please provide a Command or code.
where i add firmware file location??
4 years 8 months ago
Check Image updating from here:
http://gurux.fi/Gurux.DLMS.Client
There is no python example available at the moment, but you can easily modify have for your needs.
There are changes between the image files. Some meter manufacturers are using binary files and some hex files or JSON files.
You need to read the data from the file by yourself and then update it like described in Image updating.
Jinay Sharma
Dear Mikko,
Dear Mikko,
I'm not able to transfer image file.
what is client: {maxReceivePDUSize} in imageTransferInitiate ??
what passes argument in imageBlockTransfer fuction ??
need your support.
Meter Configuration
logicalName: 0.0.44.0.0.255
ImageBlockSize: 128
ImageTransferredBlocksStatus : 11111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
ImageFirstNotTransferredBlockNumber: 335
ImageTransferEnabled: True
ImageTransferStatus: 1
ImageActivateInfo: bytearray(b'ABCDEFG') bytearray(b'') 98028
Image File format: .bin
Meter defines max PDU size in attribute #2. Image block size.
http://gurux.fi/Gurux.DLMS.Objects.GXDLMSImageTransfer
tr = GXDLMSImageTransfer
imageBlockValue = #Read this from the file.
frames = tr.imageBlockTransfer(client, imageBlockValue, None)
Send frames to the meter using readDataBlock-method.
Jinay Sharma
I did it this way. not received any output
file = open("F:\image.bin", "rb")
ImageTransfer = GXDLMSImageTransfer()
ImageTransfer.client = settings.client
ImageTransfer.imageIdentifier = 'ABCDEFG'
ImageTransfer.forImageSize = 98028
data = ImageTransfer.imageTransferInitiate(ImageTransfer.client,ImageTransfer.imageIdentifier,ImageTransfer.forImageSize)
reply = GXReplyData()
reader.readDataBlock(data,reply)
ImageTransfer.imageBlockValue = file.read()
ImageTransfer.imageBlockCount = None
frames = ImageTransfer.imageBlockTransfer(ImageTransfer.client, ImageTransfer.imageBlockValue, ImageTransfer.imageBlockCount)
reader.readDataBlock(frames,reply)
You need to read image block size first.
