  3. Unknown Object 15 0.0.40.0.0.255
Unknown object 15 0.0.40.0.0.255
By DDobrev21 , 22 February, 2022
I am trying to connect to the Gurux DLMS server C example using HighMD5 authentication and the server reports an Unknown object 15 0.0.40.0.0.255 and the client throws an error for Access Error: Device reports an undefined object. If I am using only High authentication everything works as normal. Do you have an idea where the problem might be? Thanks.
Best regards, Dimitar
4 years 6 months ago
First, Green Book says that the use of authentication mechanisms MD5 and SHA-1 are not recommended for new implementations. So think if you really want to use MD5. Most of the meters are using GMAC.
There is no gxAssociationLogicalName for High-MD5 in the server example and that is causing this error. Add gxAssociationLogicalName for the MD5. You can copy associationHigh and modify it for your needs.
DDobrev21
Okay, Thanks for the fast
Okay, Thanks for the fast reply and for the information.
