  3. Inifinite Requests of Profile Generic Table
Inifinite requests of Profile Generic table
By Dmitry , 14 February, 2022
Hi, Mikko!
I create ProfileGeneric object (0.0.96.11.5.255). It has 5 columns.
I check "All" radio button in DLMSDirector 8.2.2202.0901.
If object has 23 rows - OK
If object has more than 23 rows (for example 24 rows) - infinite requests of data.
Exchange:
12:52:49 Read object type ProfileGeneric index: 4
7E A0 19 03 61 54 39 98 E6 E6 00 C0 01 C1 00 07 00 00 60 0B 05 FF 04 00 B9 72 7E
12:52:49
7E A0 15 61 03 74 1F C8 E6 E7 00 C4 01 C1 00 06 00 00 00 00 7D 18 7E
12:52:49 Read object type ProfileGeneric index: 5
7E A0 19 03 61 76 29 9A E6 E6 00 C0 01 C1 00 07 00 00 60 0B 05 FF 05 00 61 6B 7E
12:52:49
7E A0 12 61 03 96 22 5B E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
12:52:49 Read object type ProfileGeneric index: 6
7E A0 19 03 61 98 59 94 E6 E6 00 C0 01 C1 00 07 00 00 60 0B 05 FF 06 00 09 41 7E
12:52:49
7E A0 22 61 03 B8 AC DF E6 E7 00 C4 01 C1 00 02 04 12 00 00 09 06 00 00 00 00 00 00 0F 00 12 00 00 7C 19 7E
12:52:49 Reading profile generic data 0.0.96.11.5.255
7E A0 19 03 61 BA 49 96 E6 E6 00 C0 01 C1 00 07 00 00 60 0B 05 FF 02 00 69 26 7E
12:52:49
7E A8 86 61 03 DA 49 15 E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 03 F4 01 18 02 05 09 0C 07 E6 02 0E 07 0C 14 12 FF FF 4C 00 11 02 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 30 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 14 14 FF FF 4C 00 11 01 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 30 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 14 16 FF FF 4C 00 11 02 11 00 11 00 A3 F0 7E
12:52:49 Get next frame.
7E A0 07 03 61 D1 7F 26 7E
12:52:49
7E A8 86 61 03 DC 7F 70 0A 13 33 20 68 6F 75 72 73 2C 20 32 30 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 14 16 FF FF 4C 00 11 01 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 30 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 14 19 FF FF 4C 00 11 02 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 30 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 14 1F FF FF 4C 00 11 01 3C E7 7E
7E A0 07 03 61 F1 7D 07 7E
12:52:49
7E A8 86 61 03 DE 6D 53 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 30 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 14 2C FF FF 4C 00 11 02 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 31 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 14 3B FF FF 4C 00 11 01 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 31 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 15 01 FF FF 22 4F 7E
7E A0 07 03 61 11 73 E0 7E
12:52:49
7E A8 86 61 03 D0 13 BA 4C 00 11 02 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 31 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 15 02 FF FF 4C 00 11 01 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 31 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 15 04 FF FF 4C 00 11 02 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 31 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 2A 3D 7E
7E A0 07 03 61 31 71 C1 7E
12:52:49
7E A8 86 61 03 D2 01 99 15 05 FF FF 4C 00 11 01 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 31 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 15 07 FF FF 4C 00 11 02 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 31 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 0E 07 0C 15 07 FF FF 4C 00 11 01 11 00 11 00 0A 13 33 20 68 6F 75 72 73 2C 20 32 31 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 AF FA 7E
..... etc Get next frame
On server side i use
SetConformance((DLMS_CONFORMANCE) (GetConformance() & ~DLMS_CONFORMANCE_ACCESS));
as you write here: https://www.gurux.fi/node/19256
How to fix it?
Thanks!
4 years 5 months ago
I don't know your PDU size, but is it possible that row doesn't fit PDU?
Try to increase PDU size and let me know if you have problems.
Dmitry
On server side i call
On server side i call SetMaxReceivePDUSize(1024);
After increase to 2048 row count increased to 38 minimum but 48 rows - same problem.
I add columns:
auto l = dynamic_cast<CGXDLMSProfileGeneric*>(log);
l->SetCapturePeriod(0);
CGXDLMSClock *dtc = new CGXDLMSClock("0.0.1.0.0.255");
CGXDateTime dt;
dtc->SetTime(dt);
l->AddCaptureObject(dtc, 2, 0);
CGXDLMSData *event = new CGXDLMSData("0.0.96.11.5.255");
CGXDLMSVariant vevent(0);
vevent.ChangeType(DLMS_DATA_TYPE::DLMS_DATA_TYPE_UINT8);
event->SetValue(vevent);
l->AddCaptureObject(event, 2, 0);
CGXDLMSData *ch_num = new CGXDLMSData("0.0.96.12.4.255");
CGXDLMSVariant vch(0);
vch.ChangeType(DLMS_DATA_TYPE::DLMS_DATA_TYPE_UINT8);
ch_num->SetValue(vch);
l->AddCaptureObject(ch_num, 2, 0);
CGXDLMSData *cl_addr = new CGXDLMSData("0.0.96.12.6.255");
CGXDLMSVariant vaddr(0);
vaddr.ChangeType(DLMS_DATA_TYPE::DLMS_DATA_TYPE_UINT8);
cl_addr->SetValue(vaddr);
l->AddCaptureObject(cl_addr, 2, 0);
CGXDLMSRegister *uptime = new CGXDLMSRegister("0.0.96.8.0.255");
CGXDLMSVariant vup(std::string(""));
uptime->SetValue(vup);
l->AddCaptureObject(uptime, 2, 0);
l->SetProfileEntries(5000);
after i fill table.
I'll check this. What is the HDLC frame size?
Dmitry
On DLMSDirector side:
HDLC settings:
Max Payload size in transmit: 128
Max Payload size in recieve: 128
How to know HDLC frame size on server side?
Meter sends it when you establish the connection in Ua frame. It's the first frame that the meter sends.
If you add a hex trace here I can check the values and use them with the simulated meter.
Dmitry
Log from establish connection
Log from the beginning of connection:
GXDLMSDirector 8.2.2202.0901
Log created 10:44:47
10:44:50 Initializing Network connection.
10:44:51 Send SNRM request.
7E A0 07 03 61 93 69 47 7E
10:44:51
7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
10:44:51 Parsing UA reply succeeded.
10:44:51 Send AARQ request.
7E A0 4C 03 61 10 58 27 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 10 22 22 34 6A 75 53 07 12 25 41 2D 2B 50 6C 55 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF 3F 00 7E
10:44:51
7E A0 58 61 03 30 07 51 E6 E7 00 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 67 C6 69 73 51 FF 4A EC 29 CD BA AB F2 FB E3 46 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 04 00 00 07 99 44 7E
10:44:51 Parsing AARE reply succeeded.
10:44:51 Authenticating.
7E A0 2B 03 61 32 8D EB E6 E6 00 C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 10 77 CE C3 FF 1D BF 03 AC 19 8D 5A EB 29 11 09 9D 39 55 7E
10:44:51
7E A0 24 61 03 52 62 DC E6 E7 00 C7 01 C1 00 01 00 09 10 04 EC D7 55 29 BB 49 35 F4 2C 54 E3 75 C2 14 7F 92 C5 7E
10:45:00 Read object type ProfileGeneric index: 4
10:45:00
10:45:00 Read object type ProfileGeneric index: 5
10:45:00
10:45:00 Read object type ProfileGeneric index: 6
10:45:00
10:45:00 Reading profile generic data 0.0.96.11.5.255
10:45:00
7E A8 86 61 03 DA 49 15 E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 03 F4 01 1A 02 05 09 0C 07 E6 02 10 07 0A 29 31 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 33 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 29 34 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 33 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 29 3A FF FF 4C 00 11 02 11 00 11 00 0A 12 5B BE 7E
10:45:00 Get next frame.
10:45:00
7E A8 86 61 03 DC 7F 70 31 20 68 6F 75 72 2C 20 34 33 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 08 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0A FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0A FF FF 4C 00 11 01 11 00 11 00 0A B3 6E 7E
10:45:00
7E A8 86 61 03 DE 6D 53 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0C FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0D FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0E FF FF 4C 00 11 02 11 00 11 00 DF 98 7E
10:45:00
7E A8 86 61 03 D0 13 BA 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0F FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 10 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 11 FF FF 4C 00 11 01 11 00 11 AE F3 7E
10:45:00
7E A8 86 61 03 D2 01 99 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 13 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 19 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1B FF FF 4C 00 11 02 11 00 00 17 7E
7E A0 07 03 61 51 77 A2 7E
10:45:00
7E A8 86 61 03 D4 37 FC 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1C FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1D FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1E FF FF 4C 00 11 01 11 BB BF 7E
7E A0 07 03 61 71 75 83 7E
10:45:00
7E A8 86 61 03 D6 25 DF 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1F FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 20 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 22 FF FF 4C 00 11 02 D6 0E 7E
7E A0 07 03 61 91 7B 64 7E
10:45:00
7E A8 86 61 03 D8 5B 36 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 28 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 2A FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 31 FF FF 4C 00 11 47 5B 7E
7E A0 07 03 61 B1 79 45 7E
10:45:00
7E A0 24 61 03 DA 22 D4 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 D1 E3 7E
10:45:00 Get Next Data block.
7E A0 13 03 61 DC D7 4C E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
10:45:00
7E A8 86 61 03 FC 7D 51 E6 E7 00 C4 02 C1 00 00 00 00 02 00 82 03 F4 09 0C 07 E6 02 10 07 0A 2A 33 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2C 28 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 36 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 29 31 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 3A 5B 7E
10:45:00
7E A8 86 61 03 FE 6F 72 75 72 2C 20 34 33 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 29 34 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 33 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 29 3A FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 33 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 08 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 A1 9C 7E
10:45:00
7E A8 86 61 03 F0 11 9B 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0A FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0A FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0C FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 EC C6 7E
10:45:00
7E A8 86 61 03 F2 03 B8 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0D FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0E FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0F FF FF 4C 00 11 01 11 00 11 00 0A 12 31 C9 32 7E
10:45:00
7E A8 86 61 03 F4 35 DD 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 10 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 11 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 13 FF FF 4C 00 11 02 11 00 11 00 0A 12 44 A8 7E
10:45:00
7E A8 86 61 03 F6 27 FE 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 19 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1B FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1C FF FF 4C 00 11 01 11 00 11 00 0A 31 3D 7E
10:45:00
7E A8 86 61 03 F8 59 17 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1D FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1E FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 1F FF FF 4C 00 11 02 11 00 11 00 EF D1 7E
10:45:00
7E A8 86 61 03 FA 4B 34 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 20 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 22 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 28 FF FF 4C 00 11 01 11 00 11 CD A0 7E
10:45:00
7E A0 24 61 03 FC 16 90 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 D5 C2 7E
7E A0 13 03 61 FE C7 4E E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
10:45:00
7E A8 86 61 03 1E 61 95 E6 E7 00 C4 02 C1 00 00 00 00 03 00 82 03 F4 02 10 07 0A 2A 2A FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 31 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 33 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 93 3D 7E
10:45:00
7E A8 86 61 03 10 1F 7C 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2C 28 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 36 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 29 31 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 33 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 29 34 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C F4 9C 7E
10:45:00
7E A8 86 61 03 12 0D 5F 20 34 33 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 29 3A FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 33 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 08 FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0A FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 70 5E 7E
10:45:00
7E A8 86 61 03 14 3B 3A 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0A FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0C FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0D FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 2E 52 7E
10:45:00
7E A8 86 61 03 16 29 19 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0E FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 0F FF FF 4C 00 11 01 11 00 11 00 0A 12 31 20 68 6F 75 72 2C 20 34 34 20 6D 69 6E 75 74 65 73 02 05 09 0C 07 E6 02 10 07 0A 2A 10 FF FF 4C 00 11 02 11 00 11 00 0A 12 31 20 68 6F E7 EC 7E
.... etc
  • BaEdhlfwwvUqFMkOYk
  • CrzONrPdvkWUif…
  • kra4026
  • HilipLot
  • NithnCXPiBJHVG…
