  3. Dlms Server C
dlms server C
By benyamin.chesh… , 23 January, 2022
hi Sir
If we use this
#ifdef DLMS_IGNORE_MALLOC
#define GX_OCTET_STRING(X, VALUE_, SIZE_) GX_UNION2(&X, pVal = VALUE_, (DLMS_DATA_TYPE) (DLMS_DATA_TYPE_BYREF | DLMS_DATA_TYPE_OCTET_STRING), SIZE_, sizeof(VALUE_))
, we have to comment #define DLMS_IGNORE_MALLOC , but you said it does not need to be used on the server؟
void GXDLMSServer::assingBlockCipherKey(dlmsVARIANT* value)
GX_OCTET_STRING(*value, settings.base.cipher.blockCipherKey, 16);
void GXDLMSServer::assingAuthenticationKey(dlmsVARIANT* value)
GX_OCTET_STRING(*value, settings.base.cipher.authenticationKey, 16);
void GXDLMSServer::assingKek(dlmsVARIANT* value)
GX_OCTET_STRING(*value, settings.base.kek, 16);
4 years 6 months ago
This server example doesn't use malloc. If you comment #define DLMS_IGNORE_MALLOC malloc is used and this server example doesn't work. I'll add Android server example that uses malloc for the worklist.
  • BaEdhlfwwvUqFMkOYk
  • CrzONrPdvkWUif…
  • kra4026
  • HilipLot
  • NithnCXPiBJHVG…
