  3. Error Code : "Server HDLC Address Is Not Set"
Error Code : "Server HDLC address is not set"
By jeaswb , 29 December, 2021
I'm trying to adapt client(c base) example to my code. I have a dlms meter and i can read it with your gurux director program.
I'm using addresses as Client:16 ,server:129 for public reading and it works at my code. When i passing to encryption mode im getting ""Server HDLC address is not set" at getAssociationview part.
To read objects at encryption mode im using client as 1.
Im doing same configuration from program and it works. (both public and encrypted mode )
I checked my keys and im pretty sure there is no problem at keys side.
mode is DLMS_INTERFACE_TYPE_HDLC_WITH_MODE_E
Authentication : DLMS_AUTHENTICATION_NONE
ciphering security: DLMS_SECURITY_AUTHENTICATION_ENCRYPTION
i waiting for your solution.
Thank you
4 years 7 months ago
Can you add messages as a hex string so I can verify them?
jeaswb
Do you ask for sending
Do you ask for sending&receiving messages from serial port ?
4 years 6 months ago
Yes, if you can add them I can verify what is happening.
  • CorwXGlcWwyuiJawypxb
  • Vegazone-Casin…
  • VegaZone-lBit
  • Vegazone-Sverige-Fug
  • UIRlLOZQoyTZHC…
