  3. [Gurux.DLMS.Python] ValidateAare Invalid Tag Error
[Gurux.DLMS.Python] validateAare Invalid tag error
By pablo.ospino , 7 December, 2021
Hi there,
I have a problem with the connection with my Landis+Gyr E650 Meter through IP/PORT.
Here I attach the dataframes.
RX: 10:32:23 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 10:32:23 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF 80 AB 7E
RX: 10:32:24 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 10:32:24 7E A0 07 03 21 53 03 C7 7E
RX: 10:32:25 7E A0 37 21 03 30 6C 7C E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 0F 04 0D 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 0A A8 7E
In any case, in the python code appears the following error.
--> ValueError: Invalid tag. on the validateAareResponse method.
```python
reply = GXReplyData()
data = self.client.snrmRequest()
if data:
self.client.parseUAResponse(reply.data)
size = self.client.limits.maxInfoTX + 40
self.replyBuff = bytearray(size)
reply.clear()
self.readDataBlock(self.client.aarqRequest(), reply)
self.client.parseAareResponse(reply.data) <============= ERROR Happens here
reply.clear()
What could it be the cause of it? Is there any extra information I can provide to help solve this issue?
Thanks!
4 years 7 months ago
The content of the data is correct, but data comes in the wrong order and some of the data is echoed. Are you using Moxa, etc. that might cause this? I believe that your meter is not using TCP/IP module?
pablo.ospino
Thanks Mikko for the quick
Thanks Mikko for the quick response.
I am using a Landys gyr meter. Specifically the one with model E650.
does this one need to install the TCP/IP module?
If you are using Communication Units E20 there should be no problem. You can connect directly to the meter. Are you using RS-232 to TCP/IP router?
pablo.ospino
Thanks a lot, I will check and let you know.
Another fact is that the meter can correctly connect to the software .dMap110 from LandysGyr through TCP/IP without any problem.
The data frames that you added are invalid. Have you tried to read the meter with DLMS client example?
parameters are something like:
-h YOUR_METER_ADDRESS -p YOUR_METER_PORT -r sn -t Verbose
  • CorwXGlcWwyuiJawypxb
  • Vegazone-Casin…
  • VegaZone-lBit
  • Vegazone-Sverige-Fug
  • UIRlLOZQoyTZHC…
