  3. Certificate Data Is Not Updates In UI In Gurux
Certificate data is not updates in UI in gurux
By aoudumbarpawar , 27 November, 2021
Hii,
How are you?
Hope you are doing well.
I have an issue with certificate info attribute of security setup class.
I want to read the certificate info using block transfer, the logs seems correct and working well with another utility.
From the log it seems that certificate data is readed successfully by gurux but not updated in UI only first block certificate is getting updated in UI.
Following is the log and attached the snap.
Log :
12:58:18 Read object type SecuritySetup index: 2
TX: 7E A0 1C 00 02 BA 69 61 98 97 AC E6 E6 00 C0 01 C1 00 40 00 00 2B 00 01 FF 02 00 1C 33 7E
12:58:19
RX: 7E A0 15 61 00 02 BA 69 B8 51 73 E6 E7 00 C4 01 C1 00 16 FC F0 3D 7E
12:58:19 Read object type SecuritySetup index: 3
TX: 7E A0 1C 00 02 BA 69 61 BA 87 AE E6 E6 00 C0 01 C1 00 40 00 00 2B 00 01 FF 03 00 C4 2A 7E
12:58:19
RX: 7E A0 15 61 00 02 BA 69 DA 45 33 E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
12:58:19 Read object type SecuritySetup index: 4
TX: 7E A0 1C 00 02 BA 69 61 DC B7 A8 E6 E6 00 C0 01 C1 00 40 00 00 2B 00 01 FF 04 00 CC 67 7E
12:58:19
RX: 7E A0 1D 61 00 02 BA 69 FC 9D A9 E6 E7 00 C4 01 C1 00 09 08 31 32 33 34 35 36 37 38 86 D9 7E
12:58:19 Read object type SecuritySetup index: 5
TX: 7E A0 1C 00 02 BA 69 61 FE A7 AA E6 E6 00 C0 01 C1 00 40 00 00 2B 00 01 FF 05 00 14 7E 7E
12:58:19
RX: 7E A0 1D 61 00 02 BA 69 1E 81 6D E6 E7 00 C4 01 C1 00 09 08 50 52 4F 7C 23 45 6E F0 66 E9 7E
12:58:19 Read object type SecuritySetup index: 6
TX: 7E A0 1C 00 02 BA 69 61 10 D7 A4 E6 E6 00 C0 01 C1 00 40 00 00 2B 00 01 FF 06 00 7C 54 7E
12:58:19
RX: 7E A0 72 61 00 02 BA 69 30 8C 18 E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 00 51 01 01 02 06 16 00 16 00 09 03 0F 4A F3 09 31 43 4E 3D 52 6F 6F 74 20 43 41 20 32 35 36 2C 20 4F 3D 47 75 72 75 78 20 53 65 63 75 72 69 74 79 2C 20 4C 3D 54 61 6D 70 65 72 65 2C 20 43 3D 46 49 09 13 43 4E 3D 35 30 35 32 34 46 37 43 32 33 34 35 36 45 46 30 09 00 F1 55 7E
12:58:19
TX: 7E A0 16 00 02 BA 69 61 32 90 4F E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
12:58:20
RX: 7E A0 72 61 00 02 BA 69 52 98 58 E6 E7 00 C4 02 C1 00 00 00 00 02 00 82 00 51 01 01 02 06 16 00 16 01 09 03 0F 4A F4 09 31 43 4E 3D 52 6F 6F 74 20 43 41 20 32 35 36 2C 20 4F 3D 47 75 72 75 78 20 53 65 63 75 72 69 74 79 2C 20 4C 3D 54 61 6D 70 65 72 65 2C 20 43 3D 46 49 09 13 43 4E 3D 35 30 35 32 34 46 37 43 32 33 34 35 36 45 46 30 09 00 11 20 7E
12:58:20
TX: 7E A0 16 00 02 BA 69 61 54 A0 49 E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
12:58:20
RX: 7E A0 72 61 00 02 BA 69 74 AC 1C E6 E7 00 C4 02 C1 00 00 00 00 03 00 82 00 51 01 01 02 06 16 01 16 00 09 03 0F 4A F1 09 31 43 4E 3D 52 6F 6F 74 20 43 41 20 32 35 36 2C 20 4F 3D 47 75 72 75 78 20 53 65 63 75 72 69 74 79 2C 20 4C 3D 54 61 6D 70 65 72 65 2C 20 43 3D 46 49 09 13 43 4E 3D 33 31 33 32 33 33 33 34 33 35 33 36 33 37 33 38 09 00 61 6E 7E
12:58:20
TX: 7E A0 16 00 02 BA 69 61 76 B0 4B E6 E6 00 C0 02 C1 00 00 00 03 43 9D 7E
12:58:20
RX: 7E A0 72 61 00 02 BA 69 96 B0 D8 E6 E7 00 C4 02 C1 00 00 00 00 04 00 82 00 51 01 01 02 06 16 01 16 01 09 03 0F 4A F2 09 31 43 4E 3D 52 6F 6F 74 20 43 41 20 32 35 36 2C 20 4F 3D 47 75 72 75 78 20 53 65 63 75 72 69 74 79 2C 20 4C 3D 54 61 6D 70 65 72 65 2C 20 43 3D 46 49 09 13 43 4E 3D 33 31 33 32 33 33 33 34 33 35 33 36 33 37 33 38 09 00 25 46 7E
12:58:20
TX: 7E A0 16 00 02 BA 69 61 98 C0 45 E6 E6 00 C0 02 C1 00 00 00 04 FC E9 7E
12:58:20
RX: 7E A0 6D 61 00 02 BA 69 B8 F1 BC E6 E7 00 C4 02 C1 01 00 00 00 05 00 82 00 4C 01 01 02 06 16 02 16 03 09 03 0F 48 5A 09 31 43 4E 3D 52 6F 6F 74 20 43 41 20 32 35 36 2C 20 4F 3D 47 75 72 75 78 20 53 65 63 75 72 69 74 79 2C 20 4C 3D 54 61 6D 70 65 72 65 2C 20 43 3D 46 49 09 0E 43 4E 3D 52 6F 6F 74 20 43 41 20 32 35 36 09 00 33 9D 7E
12:59:20 Send Keep Alive
TX: 7E A0 1C 00 02 BA 69 61 BA 87 AE E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 01 00 F9 79 7E
12:59:30 Failed to receive reply from the device in given time.
12:59:30 Disconnect request
TX: 7E A0 0A 00 02 BA 69 61 53 4C 39 7E
12:59:30
RX: 7E A0 0A 61 00 02 BA 69 1F D9 0E 7E
AP
aoudumbarpawar
4 years 8 months ago
sorry certificate data not
sorry certificate data not *date
aoudumbarpawar
Hii,
Hii,
Sorry for bothering you, I found the solution and able to get all certificates info now.
Thanks!!!
AP
I'm glad you solved this. I notest that the amount of the certificates was wrong.
  • AFVCepooxRHqhZHtRg
  • Afham
  • isabelbf3
  • xkQAHLRbrboWkI…
  • RBCLQVpfdDeeYPPbKksI
