  3. Using GXDLMS To Create and Read Image(packets To Send/receive)
Using GXDLMS to create and read image(packets to send/receive)
By Virus , 17 November, 2021
Good day
I have application (win32) that works with IEC commands reading Load Profile and Billing Data.
It can use Network, USB and Modem.
After meter connection and <ACK>202 meter in dlms mode, how do I create correct message to send via Network( send(socket, message, messageLength,0)) and how to interoperate received data.
I want to read Landis Gyr meter Registers one at a time.
5 years ago
IEC 62056-21 and DLMS/COSEM are different procols.
In DLMS you don't just read the value, you need first to establish the connection to the meter before you can read anything. I strongly propose that you use Gurux Open Source libraries to read your meter if you need to use DLMS. DLMS is not an easy protocol where you just send a message and get a reply.
Virus
5 years ago
I want to use the GuruX Open
I want to use the GuruX Open Source libraries to read meter after establishing TCP connection.
Is there a way to hand a socket over to GuruX libraries after succesfull connection and then do readings?
5 years ago
Gurux libraries only generate and parse the data. You need to send the generated bytes using a communication channel that you like. In this case TCP/IP or UDP. Check the client example it will do what you want to do.
