  3. Change Access Rights For Attributes and Methods
Change access rights for attributes and methods
By bhatiasidharth.89 , 2 November, 2021
I want to change the access rights for an object's individual attributes and methods. How should I do this? I am using the Arduino server example. I could change the attribute rights for IEC HDLC setup object by modifying the switch case in the function getHdlcSetupAttributeAccess. But I could not find how to do it for the clock and security setup objects.
Also, I could not find how to change the access rights for methods of any object.
Please guide.
Regards
Sidharth
4 years 10 months ago
You do it the same way as getHdlcSetupAttributeAccess. Just modify switch case for your needs.
You can find example for SetupAttributeAccess here:
https://github.com/Gurux/GuruxDLMS.c/blob/4ec295d3d316bacd267a86166f341…
bhatiasidharth.89
Ok. Thanks Mikko. And how do
Ok. Thanks Mikko. And how do I change the access rights for methods of any object?
Regards
Sidharth
You can do it in svr_getMethodAccess as the same way as svr_getAttributeAccess.
