  3. Gateway Protocol Support In Python/Gurux
Gateway protocol support in Python/Gurux
By bmansvk , 24 September, 2021
Gurux.Serial
Does the Python/Gurux supports gateway protocol (similarly as Gurux Dlms Director)?
Please could you point me to some documentation/specification which describes gateway protocol (some IEC spec, or DLMS spec.)?
Miroslav
4 years 11 months ago
Hi Miroslav,
Hi Miroslav,
Gateway protocol is defined in DLMS Green Book at 10.9.
Gateway protocol is not widely used and I can't remember if any of our clients using it with Delphi, but it should work with Python.
gilles_de_rais
3 years 5 months ago
Hi I have tried searching…
I have tried searching for a way to use a gateway in gurux/python but i was not able to find it i have used it in guruxdirector.
In reply to Hi I have tried searching… by gilles_de_rais
Hi, Please, if you have a…
Please, if you have a new question create a new topic.
Gateway protocol is defined in the DLMS Green Book. It's implemented for Python and you can use it like this:
cl = GXDLMSClient(...)
cl.gateway = GXDLMSGateway()
cl.gateway.networkId = YOUR_NETWORK_ID
cl.gateway.physicalDeviceAddress = YOUR_DEVICE_ADDRESS
