  3. Adding New Objects To Sample Arduino Code
Adding new objects to sample Arduino code
By bhatiasidharth.89 , 20 September, 2021
Can you please explain with an example about how I can add new objects to the sample Arduino code? The default code has a very limited number of objects. I would like to understand how I can add more of these according to my needs.
Thanks and Regards
Sidharth
4 years 10 months ago
Hi Sidharth,
Hi Sidharth,
You need to create a new instance from the object. Then initialize it and add it to the association view. Then you need handle it on _read, _write or _action or if you can read value from the memory, you don't need handle read. Just initialize memory address where value can read.
static gxRegister reActivePowerL1;
static gxObject* ALL_OBJECTS[] = {..., BASE(reActivePowerL1)};
const unsigned char ln[6] = { 1, 1, 23, 25, 0, 255 };
if ((ret = INIT_OBJECT(reActivePowerL1, DLMS_OBJECT_TYPE_REGISTER, ln)) == 0)
reActivePowerL1.Value = 10;
GX_UINT16_BYREF(reActivePowerL1.value, activePowerL1Value);
//10 ^ 3 = 1000
reActivePowerL1.scaler = 3;
reActivePowerL1.unit = 30;
http://www.gurux.fi/Gurux.DLMS.Server
bhatiasidharth.89
Thanks Mikko,
Thanks Mikko,
I was able to use this information to add a register object and a script table object to the code.
Regards
Sidharth
Hi Sidharth,
Hi Sidharth,
You should check the GuruxDLMSServerExample2. There are a lot of examples of how to add different COSEM objects to the server.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
