  3. Get PlainText In Client
Get PlainText in Client
By Bhaumik , 6 September, 2021
I am creating one test application using Gurux.DLMS library.
In that I want to print plain text (decrypted) of request-response in log.
Is that possible to take plain text from client? Or anyother way
Please suggest.
5 years ago
What programming language are you using?
Bhaumik
5 years ago
Hi, I am using c# language.
5 years ago
If you listen GXDLMSClient.OnPdu notification you can print decrypted messages.
Bhaumik
5 years ago
As per your suggestion, I am able to print PDU.
But, Is it possible to print full payload instead of only PDU.
5 years ago
You can use GXDLMSTranslator to convert PDU to XML. You should check GXDLMSTranslator.PduToXml-method.
