  3. Gurux Gives Error of "Not Enough Data"
Gurux gives error of "Not Enough data"
By vivekchitte , 31 July, 2021
When I am connected gurux to my meter using suite 1 High level with ECDSA authentication mechanism it shows a pop-up error message "Not enough data".
please guide me to resolve this error.
thank you.
4 years 11 months ago
Can you add sent and received bytes as a hex?
vivekchitte
please check the below log reply for your reference. this happens when I am trying to connect to the meter.
GXDLMSDirector 8.2.2107.2101
Log created 12:36:01
12:36:04 Initializing Network connection.
12:36:04 Send AARQ request.
00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 07 AC 12 80 10 50 0F 2D 30 05 44 05 64 30 61 5D 48 25 73 4A 27 BE 23 04 21 21 1F 31 00 00 00 00 A5 C9 10 AF E4 9C DC DA F0 CD AA 4E 8B 29 7C BD 0D DE CA 36 78 8A EB 74 9C CC
12:36:04
00 01 00 01 00 30 00 97 61 81 95 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 7B 04 79 28 77 31 00 00 00 02 F7 F2 D6 B5 E7 F7 62 AB EF 07 E1 81 73 DF 11 A3 50 7C 30 81 49 45 B6 63 BB 8D FA 66 DD 55 B2 BB B8 0C 50 DB C4 1B D3 7B 6A 55 34 3A E5 5A 18 83 56 AC 41 66 7D 4B 1A 84 0B 1C F1 21 1F 98 24 8E B2 71 6E 78 B6 5B 4F 0A 16 79 88 86 41 5A 72 46 DD 73 9B FB B8 E7 3D C0 09 CB 16 FE B1 16 91 D5 DC 6A C2 53 1A 87 77 E4 49 AD F4 1A 58 93 13 2A 57 80
System.Exception: Not enough data.
thank you
One byte is missing from the reply and it's causing this.
61 81 95 //There are only 148 bytes. This must be fixed for the meter.
Meter doesn't accept the connection and returns the PermanentRejected error. Because I don't have the certificates I can't check this.
vivekchitte
please check the below-updated log reply for your reference.
Log created 12:28:23
12:28:26 Initializing Network connection.
12:28:26 Send AARQ request.
00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 07 AC 12 80 10 61 01 45 5E 08 3C 09 61 0B 12 3E 68 75 6B 37 02 BE 23 04 21 21 1F 31 00 00 00 00 A5 C9 10 AF E4 9C DC DA F0 CD AA 4E 8B 29 7C BD 0D DE CA 36 78 8A EB 74 9C CC
<WRAPPER len="67" >
<TargetAddress Value="30" />
<SourceAddress Value="1" />
<PDU>
<AssociationRequest>
<CallingAPTitle Value="3132333435363738" />
<MechanismName Value="HighECDSA" />
<CallingAuthentication Value="6101455E083C09610B123E68756B3702" />
<glo_InitiateRequest Value="3100000000A5C910AFE49CDCDAF0CDAA4E8B297CBD0DDECA36788AEB749CCC" />
</AssociationRequest>
</PDU>
</WRAPPER>
12:28:26
00 01 00 01 00 30 00 97 61 81 95 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 7B 04 79 28 77 31 00 00 00 03 D6 D7 90 F5 75 7F AA 54 1B BB 69 8C 17 39 35 88 BD 21 84 8C 24 01 E6 D2 D5 E9 56 C3 44 71 B4 BE CE E1 DD 95 0A 45 37 99 DF EA 80 33 69 96 F5 62 C4 B9 CB 67 E4 1B 2F CA CC 49 18 65 0B 58 3F 62 84 33 4E 67 AC DF BD 59 7F 09 40 02 7B 34 22 B6 BE D3 8C A7 36 D7 98 FD 03 6D 8B 47 A9 8E FE E5 3A 0D CD FE E9 73 3D 8B 54 4A 57 51 50 F5 F1 A4 20 98
<WRAPPER len="9F" >
<TargetAddress Value="1" />
<SourceAddress Value="30" />
<PDU>
<AssociationResponse>
<AssociationResult Value="01" />
<ResultSourceDiagnostic>
<ACSEServiceUser Value="01" />
</ResultSourceDiagnostic>
<glo_InitiateResponse Value="3100000003D6D790F5757FAA541BBB698C17393588BD21848C2401E6D2D5E956C34471B4BECEE1DD950A453799DFEA80336996F562C4B9CB67E41B2FCACC4918650B583F6284334E67ACDFBD597F0940027B3422B6BED38CA736D798FD036D8B47A98EFEE53A0DCDFEE9733D8B544A575150F5F1A42098" />
</AssociationResponse>
</PDU>
</WRAPPER>
thank you
  • Vegazone-au
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
