  3. How To Read Single OBIS Command and Get Result Using Android Library
How to read single OBIS command and get result using android library
By Virabhadrappa , 13 July, 2021
Gurux DLMS for Android
Hi sir,
We are using android library. How we can communicate meter using single OBIS command?. Is there any code or reference? Please help.
Ex: logical name: 0.0.1.0.0.255
output data: 13/07/2021 16:24:10
5 years 2 months ago
You need to establish the connection to the meter before you can read anything, so you can't do this with a single command.
You can skip reading the association view and read clock object like this:
//Open the connection...
GXDLMSClock clock = new GXDLMSClock("0.0.1.0.0.255");
read(clock, 2);
//Close the connection...
Virabhadrappa
Hi sir,
Hi sir,
Thank you for your reply. We are doing open and close connection correctly. But this
read(clock); // Here accepting only one parameter not 2 param's.
Unable receive data if we pass only one parameter( i.e clock object). Is there any other code or any
modification is required?
Please help me.
Check this:
https://github.com/Gurux/Gurux.DLMS.Android/blob/036e1a1de18f45e312e40e…
Virabhadrappa
Hi sir,
Hi sir,
Open and close connection working fine. We checked this code
readObject(clock,2);
Getting message "Failed to receive reply from the device in given time".
Is there any other way or any modification is required?
Please help me.
Do you call initializeConnection method? Opening the connection is not that you just open the serial port connectio.
dhanush
Virabhadrappa which meter
Virabhadrappa which meter your using and can you tell me Meter Details
Virabhadrappa
HI sir,
HI sir,
We are using Larsen & Turbo DLMS 3-phase meter. Also tell me how to get result using
1) Data object ( i.e Exp: 0.0.42.0.0.255),
2) Register object ( i.e Exp: 1.0.32.7.0.255 (Voltage))
3) ProfileGenerica object ( i.e Exp: 1.0.99.1.0.255 (Load profile..1))
Any code how to get data. Please help me.
dhanush
Virabhadrappa can you me your
Virabhadrappa can you me your email because i am also working on same LNT 3 phase android
In reply to HI sir, by Virabhadrappa
Check the android example. It will read the association view and read all the objects from the meter.
Virabhadrappa
Hi sir,
Hi sir,
We don't want all the objects come from the meter only few i.e 7 to 8 object values. That's it. How can we get the values only manually given objects. Is there any specific way?
Please help me.
You need to add those objects like this:
GXDLMSData data = new GXDLMSData("Logical name");
readObject(data,2);
Find refresh and add objects that you want to read to there.
