  3. DLMS Python - How To Read Selected Object?
DLMS Python - How to read selected object?
By Vimukthi , 10 March, 2021
I want to read some specific objects of the DLMS meter (ex: 1.0.32.7.0.255). Can you tell me how to do this by changing the main.py without reading the association view?
R374
5 years ago
you can use switch -g to read
you can use switch -g to read any OBIS EX: -g "1.0.32.7.0.255:2"
you should Cache association view to make reading faster. Ex. -o C:\\device.xml"
here is a complete Ex on serial port :
python Gurux.DLMS.Client.Example.python\main.py -S COM10:19200:8None1 -g "1.0.32.7.0.255:2" -o C:\\device.xml
Note that it will read using public client : -c 16 -s 1
If you want to read LLS or HighGMac Authentication and different Security Level you should consider proper switches based on GXSettings.py Help!
  • Anas Zaatreh
  • QDeYZLrphMziQF…
  • sharrongm69
  • agize
  • BioTips
