  3. Time Synchronization Possibility
Time synchronization possibility
By DenisMalakhov , 28 June, 2021
Hello, is it possible to make synchronization mechanism like this https://en.wikipedia.org/wiki/Network_Time_Protocol#Clock_synchronizati…?
5 years 1 month ago
You should check If the meter is supporting NTP setup.
DenisMalakhov
5 years 1 month ago
Unfortunately, it is not
Unfortunately, it is not supported. So I would like to know if there is a way to perform proper time synchronization without an NTP configuration object?
5 years ago
The only way to do this is to establish the connection to the meter and then set the time using the Clock object.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
