  3. Authentication Mecanism Error
Authentication Mecanism error
By Diego2911 , 25 June, 2021
Hi everyone. I am trying to use python libraries to communicate with an Elster A1800 meter. I manage to apply the "readDLMSpacket" method and get the UA response. However, after applying the "parseAareResponse" method I get the "Authentication mecanism is requiered" error even though it indicates a low authentication level when starting the code with its respective password. What can this error be due to? and how can I solve it? Thank you.
I attach the photos of the errors.
Thanks and best regards.
Diego2911
5 years 5 months ago
The image
The image
5 years 4 months ago
Please, don't add images. Plain text is easier to read. Try to run application with -t Verbose argument.
and add send and received bytes. Have you changed the client address with -c argument?
Diego2911
Ok, i won't add images. Yes,
Ok, i won't add images. Yes, i changed the client address with -c argument. The client for Low level Authentication is 17 according to the meter documentation. What do you mean with "and add send and received bytes" ? Thanks for your reply.
You can see the mentioned error here:
"D:\Archivos Diego\2021 - 1\Tesis 2\Implementación\venv\Scripts\python.exe" "D:/Archivos Diego/2021 - 1/Tesis 2/Implementación/main.py"
ClientAddress: 0x11
Security: Security.AUTHENTICATION
System title: 41 42 43 44 45 46 47 48
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
File "D:/Archivos Diego/2021 - 1/Tesis 2/Implementación/main.py", line 28, in <module>
reader.initializeConnection()
File "D:\Archivos Diego\2021 - 1\Tesis 2\Implementación\GXDLMSReader.py", line 311, in initializeConnection
self.client.parseAareResponse(reply.data)
File "D:\Archivos Diego\2021 - 1\Tesis 2\Implementación\venv\lib\site-packages\gurux_dlms\GXDLMSClient.py", line 549, in parseAareResponse
self.isAuthenticationRequired = _GXAPDU.parsePDU(self.settings, self.settings.cipher, reply, None) == SourceDiagnostic.AUTHENTICATION_REQUIRED
File "D:\Archivos Diego\2021 - 1\Tesis 2\Implementación\venv\lib\site-packages\gurux_dlms\_GXAPDU.py", line 651, in parsePDU
ret = _GXAPDU.parsePDU2(settings, cipher, buff, xml)
File "D:\Archivos Diego\2021 - 1\Tesis 2\Implementación\venv\lib\site-packages\gurux_dlms\_GXAPDU.py", line 837, in parsePDU2
raise GXDLMSException(resultComponent, resultDiagnosticValue)
gurux_dlms.GXDLMSException.GXDLMSException: Connection is permanently rejected
Authentication mechanism name is required.
Diego2911
I've just run the application
I've just run the application with -t Verbose command. These are the bytes sended and recived.
ClientAddress: 0x11
TX: 02:15:45 7E A0 07 03 23 93 BF 32 7E
RX: 02:15:46 7E A0 1E 23 03 73 7B CF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 02:15:46 7E A0 83 03 23 10 AE DB E6 E6 00 60 75 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 2A 80 28 31 32 33 34 35 36 37 38 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 32 30 BE 23 04 21 21 1F 10 00 00 00 00 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF 78 BE FD 47 37 15 54 10 D2 E7 3B 01 A1 3B 7E
RX: 02:15:46 7E A0 37 23 03 30 D4 C9 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0C BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1D 02 00 00 07 82 FE 7E
I don't do anything with the python trace. I need the bytes that the client app has sent to the meter.
Run application with -t Verbose argument and you can see the trace from the sent and received bytes.
I believe that your password or client address is wrong.
You modify the source code. Reject your changes. Now you try to connect with ciphering.
Diego2911
How can i set ciphering in the command line?
You need to set security to None.
Diego2911
I just ran this command line
python main.py -S COM11 -c 17 -C None -A "1234567820202020202020202020202020202020" -t Verbose
This is the result
gurux_dlms version: 1.0.104
gurux_net version: 1.0.17
gurux_serial version: 1.0.15
ClientAddress: 0x11
TX: 03:11:33 7E A0 07 03 23 93 BF 32 7E
RX: 03:11:34 7E A0 1E 23 03 73 7B CF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 03:11:34 7E A0 2B 03 23 10 4B 9C E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
RX: 03:11:34 7E A0 37 23 03 30 D4 C9 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0C BE 10 04 0E 08 00 06 5F 1F 04 00 00 10
TX: 03:11:34 7E A0 07 03 23 53 B3 F4 7E
Connect with GXDLMSDirector and you can see correct command line parameters when you select the meter. Try with this:
python main.py -S COM11 -c 17 -A Low -P 12345678 -t Verbose
Diego2911
I got this error when i try to run that command line
File "main.py", line 44, in main
ret = settings.getParameters(args)
File "D:\Archivos Diego\2021 - 1\Tesis 2\Implementacion_2\GXSettings.py", line 244, in getParameters
self.client.ciphering.authenticationKey = GXByteBuffer.hexToBytes(it.value)
File "D:\Archivos Diego\2021 - 1\Tesis 2\Implementacion_2\venv\lib\site-packages\gurux_dlms\GXByteBuffer.py", line 582, in hexToBytes
lastValue = cls.___getValue(ch)
File "D:\Archivos Diego\2021 - 1\Tesis 2\Implementacion_2\venv\lib\site-packages\gurux_dlms\GXByteBuffer.py", line 567, in ___getValue
raise Exception("Invalid hex string")
Exception: Invalid hex string
Thanks for your help
Diego2911
I managed to connect with the
I managed to connect with the meter with GXDLMSDirector, this is the comand line wich the program gave to me:
-S COM11:9600:8NoneOne -c 17 -s 144 -a Low -P 0x4Vx -t Verbose
I set the password as 1234567820202020202020202020202020202020 in the password field without selecting the ASCII box and with the Hex box selected.
About the command line, how can i put that -P on tne command line of python?? Thanks
Try with this:
-S COM11:9600:8NoneOne -c 17 -s 144 -a Low -P 0x1234567820202020202020202020202020202020 -t Verbose
Diego2911
Thanks for the help !! I
Thanks for the help !! I managed to connect with the meter with the last command line !! Thanks !!
