  3. Unable To Read Scalar of Billing-profile From a Device.
Unable to read Scalar of billing-profile from a device.
By pradson , 21 June, 2021
I am unable to read billing profile scalars (1.0.94.91.6.255) from a device using DLMSDirector tool.
Kindly suggest what should I do? I have attached the screenshot for the same.
Apart from this, I am sharing you the DLMSDirector logs for the same through email.
Kindly check and suggest.
Thanks & Regards,
Pradson
5 years 5 months ago
Hi Pradson,
Hi Pradson,
Please, don't add images. They are compressed and reading is impossible. I can't see the error message. What version you are using?
If you select the error message box and press Ctrl+C it will copy the error message to the clipboard.
pradson
In reply to Hi Pradson, by Kurumi
As suggested, Kindly find
As suggested, Kindly find error message.
The given key was not present in the dictionary.
OK
In the log that you sent all the profile generics are empty. There are no capture objects.
