  3. Unable To Click On Checkbox In 0.0.94.91.18.255 .
Unable to click on checkbox in 0.0.94.91.18.255 .
By Mithun Tiruvedula , 8 June, 2021
I want to write to the 0.0.94.91.18.255 (Event Status Word 1 (ESW-1)) object, but am unable to change the bits by clicking on the checkbox as I am getting the following error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidCastException: Unable to cast object of type 'System.Int32' to type 'System.String'.
at Gurux.DLMS.UI.GXValueField.SetDirty(Boolean dirty, Object value)
at System.Windows.Forms.CheckedListBox.OnItemCheck(ItemCheckEventArgs ice)
at System.Windows.Forms.CheckedListBox.LbnSelChange()
at System.Windows.Forms.CheckedListBox.WmReflectCommand(Message& m)
at System.Windows.Forms.ListBox.WndProc(Message& m)
at System.Windows.Forms.CheckedListBox.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
System
Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
GXDLMSDirector
Assembly Version: 8.2.2106.701
Win32 Version: 8.2.2106.0701
CodeBase: file:///C:/Users/user/AppData/Local/Apps/2.0/WZKP6ZQ0.QJA/3X2TEC7D.EX8/gxdl..tion_fac3cc4fecb816b3_0008.0002_88c486abacb59092/GXDLMSDirector.exe
Gurux.Common
Assembly Version: 8.1.2106.101
Win32 Version: 8.1.2106.101
CodeBase: file:///C:/Users/user/AppData/Local/Apps/2.0/WZKP6ZQ0.QJA/3X2TEC7D.EX8/gxdl..tion_fac3cc4fecb816b3_0008.0002_88c486abacb59092/Gurux.Common.DLL
Gurux.MQTT
Assembly Version: 8.1.2104.801
Win32 Version: 8.1.2104.801
CodeBase: file:///C:/Users/user/AppData/Local/Apps/2.0/WZKP6ZQ0.QJA/3X2TEC7D.EX8/gxdl..tion_fac3cc4fecb816b3_0008.0002_88c486abacb59092/Gurux.MQTT.DLL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Gurux.DLMS.AMI.UI
Assembly Version: 8.1.2104.2901
Win32 Version: 8.1.2104.2901
CodeBase: file:///C:/Users/user/AppData/Local/Apps/2.0/WZKP6ZQ0.QJA/3X2TEC7D.EX8/gxdl..tion_fac3cc4fecb816b3_0008.0002_88c486abacb59092/Gurux.DLMS.AMI.UI.DLL
Assembly Version: 9.0.2106.401
Win32 Version: 9.0.2106.401
CodeBase: file:///C:/Users/user/AppData/Local/Apps/2.0/WZKP6ZQ0.QJA/3X2TEC7D.EX8/gxdl..tion_fac3cc4fecb816b3_0008.0002_88c486abacb59092/Gurux.DLMS.DLL
Gurux.DLMS.UI
Assembly Version: 9.0.2106.701
Win32 Version: 9.0.2106.0701
CodeBase: file:///C:/Users/user/AppData/Local/Apps/2.0/WZKP6ZQ0.QJA/3X2TEC7D.EX8/gxdl..tion_fac3cc4fecb816b3_0008.0002_88c486abacb59092/Gurux.DLMS.UI.DLL
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Deployment
Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Gurux.Net
Assembly Version: 8.1.2106.102
Win32 Version: 8.1.2106.102
CodeBase: file:///C:/Users/user/AppData/Local/Apps/2.0/WZKP6ZQ0.QJA/3X2TEC7D.EX8/gxdl..tion_fac3cc4fecb816b3_0008.0002_88c486abacb59092/Gurux.Net.DLL
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
System.Security
Win32 Version: 4.8.4261.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Data.SqlXml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.SqlXml/v4.0_4.0.0.0__b77a5c561934e089/System.Data.SqlXml.dll
System.Transactions
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Gurux.Serial
CodeBase: file:///C:/Users/user/AppData/Local/Apps/2.0/WZKP6ZQ0.QJA/3X2TEC7D.EX8/gxdl..tion_fac3cc4fecb816b3_0008.0002_88c486abacb59092/Gurux.Serial.DLL
Gurux.Terminal
CodeBase: file:///C:/Users/user/AppData/Local/Apps/2.0/WZKP6ZQ0.QJA/3X2TEC7D.EX8/gxdl..tion_fac3cc4fecb816b3_0008.0002_88c486abacb59092/Gurux.Terminal.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
PFA screenshot of the error.
Is there a workaround on writing to this object without using checkbox?
Thank you!
5 years 1 month ago
Usually, you don't set status word. The meter will do it. I'll create an issue from this. In the meantime you can write normal value if you select Gurux as the manufacturer and set the correct client address.
Now you can see only plain integer value.
Mithun Tiruvedula
5 years 1 month ago
Yes we usually do not write to ESW (0.0.94.91.18.255), but the manufacturer is recommending it.
I am able to connect with 'Gurux' as manufacturer, but the object access is now "Read" only, if the manufacturer is 'Indian Standard' the access is "Read, Write".
Anything I can do to change that.
5 years 1 month ago
Hi Mithun,
Hi Mithun,
Meter defines the access rights. If it's read-only you need to connect with a different access level.
I have to say, that usually you can't change this. Verify this from the meter manufacturer.
  • oLtbbWaRQMvErs…
  • Rolling Slots
  • Vegazone-Australia
  • Mathewgon
  • MichaelCab
