  3. Add Meter Feature To Gurux.DLMS.Android
Add Meter feature to Gurux.DLMS.Android
By forough , 5 May, 2021
Gurux DLMS for Android
Hi there
I'm new to this protocol and i want to add our Meter feature to this package and read the data.How can i do that .Please kindly help me
Thank you
5 years 6 months ago
If you can read the meter with GXDLMSDirector send the manufacturer settings file to me.
You can find manufacturer setting files from here:
C:\ProgramData\Gurux\OBIS
After it's released you can see your settings in Gurux.DLMS.Android example application and read the meter.
forough
Thanks for reply
Thanks for reply
There is no manufacturer name for my meter
How can I initial setting for my meter to read the meter?
Read this:
https://www.gurux.fi/GXDLMSDirector.Manufacturers
The easiest way is if you rename grx.obx to your company flag name. Then modify Gurux settings for your needs.
forough
Is there any other solution
Is there any other solution to add meter's manufacturer settings to DLMS source code by me?
You can hard code the settings to the source code. Find GXDLMSSecureClient constructor and set correct parameters.
