  3. Arduino IDE Libraries For DLMS
Arduino IDE libraries for DLMS
By Diego2911 , 3 May, 2021
I have a question. I want to use the libraries on C language on Arduino IDE. What model of arduino do i need and what components do i need to implement it. Best Regards.
5 years 6 months ago
DLMS needs quite a lot of RAM and flash. It depends on what you want to read from the meter and do you need and do you need ciphering, etc. You can comment out useless functionality from gxignore.h -file and reduce the memory usage.
If you want to read profile generic (historical data), read example one day at a time. In that way amount of the data is reasonable.
Adaranijo
3 years 11 months ago
what if I just want to read
what if I just want to read my current, power and voltage. no need for ciphering
AT Mege is a good choise. For example Leonardo the flash size is 32kB and it's not enough.
