  3. Build Gurux.DLMS Cpp Lib For Windows
Build Gurux.DLMS cpp lib for Windows
By Dmitry , 23 November, 2020
Hi!
I downloaded Gurux.DLMS cpp from github.
Created empty project (Qt Creator) and added all sources lib files to project. Then run building but failed.
Error: 'inet_ntop' was not declared in this scope
..\guruxlib_test\guruxlib\src\GXDLMSIp6Setup.cpp:97:13: error: 'inet_ntop' was not declared in this scope
inet_ntop(AF_INET6, &(*it), tmp, sizeof(tmp));
..\guruxlib_test\guruxlib\src\GXDLMSIp6Setup.cpp:97:13: note: suggested alternative: 'inet_ntoa'
inet_ntoa
Windows 10, MinGW
How to fix it?
Thanks!
For Linux - OK.
5 years 8 months ago
You need to add Ws2_32.lib to your linker inputs.
Dmitry
5 years 3 months ago
Hi!
Hi!
Thanks for you reply.
I added to .pro-file
win32: LIBS += -lWS2_32
but nothing. What i'm doing wrong? Thanks!
I add DLMS_IGNORE_IP6_SETUP to compiler flags to ignore IPv6 functionality. I believe it's the easiest way to solve this.
Dmitry
Yes, it works.
Yes, it works.
I added to .pro file
DEFINES += DLMS_IGNORE_IP6_SETUP
Thanks!
  • EdwinObjef
  • LutzG
  • Ralf Schmitz
  • prosper.abanga
  • moGiaco
