  3. How To Use HIGH Security Connection
How to use HIGH security connection
By taher_alfalah , 29 March, 2021
Gurux DLMS for Android
I have a small issue to use the high-security level.
I fill the below code
mDevice.setAuthentication(Authentication.HIGH_GMAC);
mDevice.setPassword("55Wvl%9z");
mDevice.setSecurity(Security.AUTHENTICATION_ENCRYPTION);
mDevice.setSystemTitle( "4B464DD0055D4CE1");
mDevice.setBlockCipherKey("FEE0FEE0FEE0FEE0FEE0FEE0FEE0FEE0");
mDevice.setAuthenticationKey("FEA0FEA0FEA0FEA0FEA0FEA0FEA0FEA0");
mDevice.setClientAddress(11);
mDevice.setAddressType(HDLCAddressType.DEFAULT);
mDevice.setPhysicalAddress(16);
mDevice.setLogicalAddress(1);
but I got an error when I try to connect ("Connection is permanently
rejected, The application context name is not supported")
also, I try to add the below code part to make sure the security applies to
the client and the same result.
mClient = new GXDLMSSecureClient(true, mDevice.getClientAddress(),
serverAddress,
mDevice.getAuthentication(), mDevice.getPassword() , InterfaceType.HDLC);
mClient.getCiphering().setSystemTitle(GXCommon.hexToBytes("4B464DD0055D4CE1"));
mClient.getCiphering().setSecurity(Security.AUTHENTICATION_ENCRYPTION);
mClient.getCiphering().setSecuritySuite(SecuritySuite.AES_GCM_128);
mClient.getCiphering().setAuthenticationKey(GXCommon.hexToBytes(mDevice.getAuthenticationKey())
mClient.getCiphering().setBlockCipherKey(GXCommon.hexToBytes(mDevice.getBlockCipherKey())
5 years 8 months ago
There are a few reasons for this.
1. Your client address is wrong.
2. Meter is not supporting GMac.
3. Your keys are wrong.
The reason is usually one of those.
taher_alfalah
thank you for your prompt reply,
our meter manufacturer provided the attached file and we need to verify that the GUK is the same needed block cipher key.
kindly note that the low security passed successfully.
You have set authentication to HIGH_GMAC. You don't need the password if you are using GMac authentication. Try to connect using the same authentication as without ciphering. Change just the ciphering to AUTHENTICATION_ENCRYPTION.
taher_alfalah
5 years 7 months ago
I am using these settings and still have the same issue. ("Connection is permanently
rejected, The application context name is not supported").
the client address and the key as provided by the manufacturer.
mDevice.setManufacturer("KFM");
mDevice.setStartProtocol(StartProtocolType.IEC);
mDevice.setWaitTime(7);
mDevice.setSystemTitle( "4B464DD0755D4CE1");
mDevice.setAuthenticationKey("FEE0FEE0FEE0FEE0FEE0FEE0FEE0FEE0");
mDevice.setClientAddress(12);
mClient.getCiphering().setSecuritySuite(SecuritySuite.AES_GCM_128); mClient.getCiphering().setAuthenticationKey(GXCommon.hexToBytes("FEE0FEE0FEE0FEE0FEE0FEE0FEE0FEE0") );
One of the settings is wrong. Try to change HIGH_GMAC to LOW. As I told you before, I don't know is your meter supporting GMAC authentication.
taher_alfalah
4 years 3 months ago
I tried the below log and chared with the manufacturer and told me the issue in some commands requests security 0 not 5
<- ١٥:١٧:٤٤.٤٠٧ 2F 3F 21 0D 0A
->١٥:١٧:٤٥.٠٩٢ 2F 41 45 43 35 5C 32 0D 0A
<- ١٥:١٧:٤٥.١١٥ 06 32 35 32 0D 0A
<- ١٥:١٧:٤٦.٧٢٣ 7E A0 0A 00 02 00 21 19 93 C2 BC 7E
-> ١٥:١٧:٤٦.٨٣٢ 7E A0 23 19 00 02 00 21 73 CE 10 81 80 14 05 02 05 DC 06 02 05 DC 07 04 00 00 00 01 08 04 00 00 00 01 A9 0D 7E
<- ١٥:١٧:٤٦.٨٨٥ 7E A0 6E 00 02 00 21 19 10 A2 C1 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 45 43 01 01 CE A7 7C 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 26 07 65 3F 4A 67 18 4F 5F 2D 19 00 75 1C 2F 19 BE 23 04 21 21 1F 30 00 00 00 0D 68 A9 12 AB F8 D7 D7 9B 1B 8B B6 17 6F BA 89 86 37 9E 0D 69 18 93 12 44 71 5F 36 7D 7E
-> ١٥:١٧:٤٧.٢٥٥ 7E A0 72 19 00 02 00 21 30 4B 8D E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 45 43 01 01 CE A7 7C 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 6B 54 44 43 75 70 56 49 BE 23 04 21 28 1F 30 00 00 00 0B CA 98 26 32 D5 B0 2D 13 BF AA F7 C0 7A 77 D8 8C 90 AB 98 01 71 57 B6 69 44 5D BC 0C 7E
<- ١٥:١٧:٥٧.١٥٨ 7E A0 42 00 02 00 21 19 32 AB 11 E6 E6 00 CB 31 30 00 00 00 0E D8 53 96 59 FE 1D FD 21 11 F8 E3 74 E2 37 99 0D 60 FB DD 0E 93 7E CF EA A7 4D 4A 8A 98 7F 27 B8 6A 5C 36 79 6D 1A A7 85 8C B8 6C A1 F1 86 7E
-> ١٥:١٧:٥٧.٥٧٧ 7E A0 29 19 00 02 00 21 52 12 C9 E6 E7 00 CF 18 30 00 00 00 0C DD 96 49 0B 37 19 3A DD 4A 77 11 C5 A3 9C 30 90 A2 A7 37 F8 F9 7E
and the code I used is for Association and working with other meters.
do you have any advice?
code:
byte[] data = mClient.snrmRequest();
if (data.length != 0) {
readDLMSPacket(mDevice,mClient, data, reply);
mClient.parseUAResponse(reply.getData());
reply.clear();
for (byte[] it : mClient.aarqRequest()) {
readDLMSPacket( mDevice, mClient,it, reply);
mClient.parseAareResponse(reply.getData());
reply.clear();
if (mClient.getIsAuthenticationRequired()) {
for (byte[] it : mClient.getApplicationAssociationRequest()) {
readDLMSPacket(mDevice, mClient, it, reply);
mClient.parseApplicationAssociationResponse(reply.getData());
You need to read the invocation counter first. It's a data object with logical name 0.0.40.0.0.255. Check how it's done in updateFrameCounter method.
https://github.com/Gurux/gurux.dlms.java/blob/250a86fda9ec481aabf485fca…
taher_alfalah
thank you for the replay.
I already read the invocation counter and increased it and there are other meters from different brands working correctly. but this meter not working and the manufacturer sends me the above comment and I'm not sure he catches the issue.
here is my code
_mClient.getCiphering().setSecurity(Security.AUTHENTICATION_ENCRYPTION);
_mClient.getCiphering().setSecuritySuite(SecuritySuite.AES_GCM_128);
_mClient.getCiphering().setInvocationCounter(33);
and this is the Invocation counter OBIS "0.0.43.1.5.255"
Best Regards
Hi ,
Hi ,
The problem is this line.
You need to read the IC from the meter and then update the IV using setInvocationCounter.
Check the updateFrameCounter example from the link above.
  • Gabice William
  • ngewe
  • jojon15
  • murni21
  • yanto03
