  3. PDU Translator
PDU Translator
By greenMike , 15 March, 2021
I got the data decrypted so far. I just need to translate them with which function do I do this? I checked the data with the translator in the GXDLMSDirector on Windows.
I just need the function from PDU to XML
I'm programming in Python.
BR, Michael
5 years 8 months ago
You can use GXDLMSTranslator for that. Something like this:
tr = GXDLMSTranslator()
tr.pduToXml(pdu_from_the_meter)
greenMike
Thank you for the quick
Thank you for the quick answer. Which imports I need.
from gurux_dlms.GXDLMSTranslator import GXDLMSTranslator
greenMike
5 years 7 months ago
I have tested this function so far and am almost satisfied with the result. Unfortunately, it doesn't give the same result as when I use the online translator.
Decrypted data:
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
Online Translater:
<DataNotification>
<LongInvokeIdAndPriority Value="2147692551" />
<!--2021-02-04 09:18:45-->
<DateTime Value="07E502040409122D00FFC402" />
<NotificationBody>
<DataValue>
<Structure Qty="35" >
<OctetString Value="07E502040409122D00FFC402" />
<!--1.0.1.8.0.255-->
<OctetString Value="0100010800FF" />
<UInt32 Value="99107" />
<Structure Qty="2" >
<Int8 Value="0" />
<Enum Value="30" />
</Structure>
<!--1.0.2.8.0.255-->
<OctetString Value="0100020800FF" />
<UInt32 Value="280" />
<Int8 Value="0" />
<Enum Value="30" />
</Structure>
<!--1.0.1.7.0.255-->
<OctetString Value="0100010700FF" />
<UInt32 Value="76" />
<Int8 Value="0" />
<Enum Value="27" />
</Structure>
<!--1.0.2.7.0.255-->
<OctetString Value="0100020700FF" />
<UInt32 Value="0" />
<Int8 Value="0" />
<Enum Value="27" />
</Structure>
<!--1.0.32.7.0.255-->
<OctetString Value="0100200700FF" />
<UInt16 Value="2292" />
<Int8 Value="-1" />
<Enum Value="35" />
</Structure>
<!--1.0.52.7.0.255-->
<OctetString Value="0100340700FF" />
<UInt16 Value="2291" />
<Int8 Value="-1" />
<Enum Value="35" />
</Structure>
<!--1.0.72.7.0.255-->
<OctetString Value="0100480700FF" />
<UInt16 Value="2330" />
<Int8 Value="-1" />
<Enum Value="35" />
</Structure>
<!--1.0.31.7.0.255-->
<OctetString Value="01001F0700FF" />
<UInt16 Value="49" />
<Int8 Value="-2" />
<Enum Value="33" />
</Structure>
<!--1.0.51.7.0.255-->
<OctetString Value="0100330700FF" />
<UInt16 Value="19" />
<Int8 Value="-2" />
<Enum Value="33" />
</Structure>
<!--1.0.71.7.0.255-->
<OctetString Value="0100470700FF" />
<UInt16 Value="1" />
<Int8 Value="-2" />
<Enum Value="33" />
</Structure>
<!--1.0.13.7.0.255-->
<OctetString Value="01000D0700FF" />
<Int16 Value="479" />
<Int8 Value="-3" />
<Enum Value="255" />
</Structure>
<OctetString Value="3137383217434AEF736EAAA1" />
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
Python Funktion:
<DataNotification>
<LongInvokeIdAndPriority Value="80033007" />
<NotificationBody>
<DataValue>
<Structure Qty="23" >
<UInt32 Value="00018323" />
<Structure Qty="02" >
<Int8 Value="00" />
<Enum Value="1E" />
</Structure>
<UInt32 Value="00000118" />
<Int8 Value="00" />
<Enum Value="1E" />
</Structure>
<UInt32 Value="0000004C" />
<Int8 Value="00" />
<Enum Value="1B" />
</Structure>
<UInt32 Value="00000000" />
<Int8 Value="00" />
<Enum Value="1B" />
</Structure>
<UInt16 Value="08F4" />
<Int8 Value="FF" />
<Enum Value="23" />
</Structure>
<UInt16 Value="08F3" />
<Int8 Value="FF" />
<Enum Value="23" />
</Structure>
<UInt16 Value="091A" />
<Int8 Value="FF" />
<Enum Value="23" />
</Structure>
<UInt16 Value="0031" />
<Int8 Value="FE" />
<Enum Value="21" />
</Structure>
<UInt16 Value="0013" />
<Int8 Value="FE" />
<Enum Value="21" />
</Structure>
<UInt16 Value="0001" />
<Int8 Value="FE" />
<Enum Value="21" />
</Structure>
<Int16 Value="01DF" />
<Int8 Value="FD" />
<Enum Value="FF" />
</Structure>
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
My question is can I pass parameters that the result is the same?
greenMike
What you mean by that the result is not the same? I checked the values and those look the same.
greenMike
How can I calculate the time? for example: <! - 2021-02-04 09:18:45 ->
And how do I find out the addresses, for example: <! - 1.0.1.8.0.255 ->
BR, greenMike
