  3. ProfileGeneric Method Reset Does Not Work
ProfileGeneric method Reset does not work
By MNN , 1 March, 2021
Gurux.DLMS.AMI
Hello.
Method Reset does not cleaning event logs. I try to send data: "<Int8 Value="0" />"
5 years 4 months ago
Try to connect with GXDLMSDirector and try to reset with that. It might be that it's not implemented. Data looks correct.
MNN
Method Reset in
Method Reset in GXDLMSDirector is correct. Method Reset is needed in AMI, will there be an implementation?
I just checked this and when you press "Reset"-button it will invoke the action when Gurux.DLMS.AMI is used.
MNN
The method is called, but the
The method is called, but the records remain in the database. I am using api /api/Object/ListObjects to display event logs and it returns all events.
  • NnmIomcqcTDVWiDuCD
  • iRnseovnShdVWR…
  • HgGuaAJJjTLjzz…
  • HYpmSpMsbgNghuph
  • ocYOMgUlQIJbgMUiQdIn
