  3. GXByteBuffer.setPosition() Is Raising ValueError("position") - PYTHON
GXByteBuffer.setPosition() is raising ValueError("position") - PYTHON
By Ugurcan , 24 February, 2021
I am new to Gurux and this is my very first question.
-> Meters are randomly raising value errors.
This can happen at any given time (initializing a connection with the meter, reading a meter, updating the firmware,...)
When I catch the error, I re-execute the operation I was performing. Sometimes this operation suddenly succeeds again, and sometimes it keeps failing.
I debugged and I found that it happens when the returned buffer array is smaller than the value on setPosition() function.
File "/lib/python3.6/site-packages/gurux_dlms/GXDLMS.py", line 987, in getTcpData
value = buff.getUInt16()
File "/lib/python3.6/site-packages/gurux_dlms/GXByteBuffer.py", line 318, in getUInt16
self.position += 2
File "/lib/python3.6/site-packages/gurux_dlms/GXByteBuffer.py", line 124, in setPosition
raise ValueError("position")
When i print the results of this error i got this:
ValueError: position error, value = 16 and length of array = 15,
ValueError: position error, value = 9 and length of array = 8,
ValueError: position error, value = 10 and length of array = 8,
ValueError: position error, value = 800 and length of array = 799
Those errors are almost always thrown at getUInt16() function and inside of the function the operation of "self.position += 2" which is calling def setPosition(self, value)
Here are some of the byte arrays I got throwing that exception.
Byte aray hex: C4 02 C1 00 00 00 00 01
Byte aray hex: 61 29 A1 09 06 07 60 85 61 29 A1 09 06 07 60 61 29 A1 09 06 07 60 00 01 00 01 00 01 00
Byte aray hex: 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00
I am using gurux_dlms==1.0.100
The fact that re-executing certain operations leading to a successful execution without performing any changes, makes me think that this might be related to network issues, or corrupted data being sent by the meter. But when I try to do the same operations using the GURUX DLMS DIRECTOR it successfully finishes nearly always
What I might be missing here?
Python version==3.8.0
Thanks in Advance.
Ugurcan Akpulat
5 years 9 months ago
There is data missing for the byte arrays that you added and that is causing this issue. Because there is only part of the data I can't say what is causing this. Can you add a failed frame that contains all the data so I can check what might be the reason for this.
Ugurcan
Authentication:
TX: 14:45:24 00 01 00 01 00 01 00 3D 60 3B A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0F 80 0D 45 6C 65 65 6E 61 5F 45 6E 65 72 67 79 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF
RX: 14:45:26 00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 04 40 00 07
TX: 14:45:27 00 01 00 01 00 01 00 1B C1 01 C1 00 08 00 00 01 00 00 FF 02 00 09 0C 07 E5 02 18 03 0E 2D 1B FF 00 00 00
RX: 14:45:28 00 01 00 01 00 01 00 04 C5 01 C1 00
TX: 14:45:28 00 01 00 01 00 01 00 12 C1 01 C1 00 01 00 00 61 61 00 FF 02 00 06 00 00 00 00
RX: 14:45:30 00 01 00 01 00 01 00 04 C5 01 C1 00
TX: 14:45:30 00 01 00 01 00 01 00 0D C0 01 C1 00 01 00 00 60 0C 05 FF 02 00
RX: 14:45:31 00 01 00 01 00 01 00 06 C4 01 C1 00 0F C1
TX: 14:45:31 00 01 00 01 00 01 00 0D C0 01 C1 00 01 01 00 00 02 00 FF 02 00
RX: 14:45:32 00 01 00 01 00 01 00 32 C4 01 C1 00 09 2C 42 4C 4E 32 31 30 31 38 7C 58 4D 58 5F 4E 32 31 5F 32 67 54 69 56 36 33 42 7C 4C 47 5A 5A 43 46 31 30 30 41 43 2E 4D 35 39 00 00 00
TX: 14:45:32 00 01 00 01 00 01 00 0D C0 01 C1 00 07 01 00 63 01 00 FF 03 00
RX: 14:45:38 C4 01 C1 00 09 2C 42 4C 00 01 00 01 00 01 00
TX: 14:45:40 00 01 00 01 00 01 00 0D C0 01 C1 00 07 01 00 63 01 00 FF 03 00
RX: 14:45:40 4E C4 01 C1 00 01 04 02
Byte array hex: 4E C4 01 C1 00 01 04 02
[210224 14:45:40] There was an error while reading meter id = 158 position error, value = 10 and length of array = 8.
Ugurcan
And another one:
And another one:
TX: 14:48:46 00 01 00 01 00 01 00 3D 60 3B A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0F 80 0D 45 6C 65 65 6E 61 5F 45 6E 65 72 67 79 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF
RX: 14:48:48 00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 04 40 00 07
TX: 14:48:48 00 01 00 01 00 01 00 1B C1 01 C1 00 08 00 00 01 00 00 FF 02 00 09 0C 07 E5 02 18 03 0E 30 30 FF 00 00 00
RX: 14:48:50 00 01 00 01 00 01 00 04 C5 01 C1 00
TX: 14:48:50 00 01 00 01 00 01 00 12 C1 01 C1 00 01 00 00 61 61 00 FF 02 00 06 00 00 00 00
RX: 14:48:51 00 01 00 01 00 01 00 04 C5 01 C1 00
TX: 14:48:51 00 01 00 01 00 01 00 0D C0 01 C1 00 01 00 00 60 0C 05 FF 02 00
RX: 14:48:53 00 01 00 01 00 01 00 06 C4 01 C1 00 0F C3
TX: 14:48:53 00 01 00 01 00 01 00 0D C0 01 C1 00 01 01 00 00 02 00 FF 02 00
RX: 14:48:54 00 01 00 01 00 01 00 32 C4 01 C1 00 09 2C 42 4C 4E 32 31 30 31 38 7C 58 4D 58 5F 4E 32 31 5F 32 67 54 69 56 36 33 42 7C 4C 47 5A 5A 43 46 31 30 30 41 43 2E 4D 35 39 00 00 00
TX: 14:48:54 00 01 00 01 00 01 00 0D C0 01 C1 00 07 01 00 63 01 00 FF 03 00
RX: 14:48:56 00 01 00 01 00 01 00 4E C4 01 C1 00 01 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0A 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 00 FF 0F 02 12 00 00
TX: 14:48:56 00 01 00 01 00 01 00 40 C0 01 C1 00 07 01 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E5 02 17 02 08 0F 00 00 00 00 00 09 0C 07 E5 02 18 03 0E 30 36 00 00 00 00 01 00
RX: 14:49:00 00 01 00 01 00 01 04 40 C4 02 C1 00 00 00 00 01 00 82 04 34 01 7B 02 04 09 0C 07 E5 02 17 02 09 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8A 41 02 04 09 0C 07 E5 02 17 02 09 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8A 68 02 04 09 0C 07 E5 02 17 02 09 2D 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8A A2 02 04 09 0C 07 E5 02 17 02 0A 00 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8A C2 02 04 09 0C 07 E5 02 17 02 0A 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8A DD 02 04 09 0C 07 E5 02 17 02 0A 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8A FE 02 04 09 0C 07 E5 02 17 02 0A 2D 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8B 2E 02 04 09 0C 07 E5 02 17 02 0B 00 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8B 6C 02 04 09 0C 07 E5 02 17 02 0B 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8B BD 02 04 09 0C 07 E5 02 17 02 0B 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8C 16 02 04 09 0C 07 E5 02 17 02 0B 2D 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8C 7E 02 04 09 0C 07 E5 02 17 02 0C 00 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8C EB 02 04 09 0C 07 E5 02 17 02 0C 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8D 59 02 04 09 0C 07 E5 02 17 02 0C 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8D B9 02 04 09 0C 07 E5 02 17 02 0C 2D 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8E 01 02 04 09 0C 07 E5 02 17 02 0D 00 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8E 49 02 04 09 0C 07 E5 02 17 02 0D 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8E 9D 02 04 09 0C 07 E5 02 17 02 0D 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8E E0 02 04 09 0C 07 E5 02 17 02 0D 2D 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8F 41 02 04 09 0C 07 E5 02 17 02 0E 00 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 8F 96 02 04 09 0C 07 E5 02 17 02 0E 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 90 16 02 04 09 0C 07 E5 02 17 02 0E 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 90 84 02 04 09 0C 07 E5 02 17 02 0E 2D 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 90 DE 02 04 09 0C 07 E5 02 17 02 0F 00 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 91 3E 02 04 09 0C 07 E5 02 17 02 0F 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 91 9D 02 04 09 0C 07 E5 02 17 02 0F 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 91 F8 02 04 09 0C 07 E5 02 17 02 0F 2D 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 92 44 02 04 09 0C 07 E5 02 17 02 10 00 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 92 82 02 04 09 0C 07 E5 02 17 02 10 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 92 BA 02 04 09 0C 07 E5 02 17 02 10 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 92 E8 02 04 09 0C 07 E5 02 17 02 10 2D 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 93 07 02 04 09 0C 07 E5 02 17 02 11 00 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 93 1F 02 04 09 0C 07 E5 02 17 02 11 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 93 31 02 04 09 0C 07 E5 02 17 02 11 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 93 3B 02 04 09 0C 07 E5 02 17 02 11 2D 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 93 41 02 04 09 0C 07 E5 02 17 02 12 00 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 93 43 02 04 09 0C 07 E5 02 17 02 12 0F 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 93 43 02 04 09 0C 07 E5 02 17 02 12 1E 00 00 00 3C 00 11 00 06 00 00 00 00 06 00 09 93 43 02 04 09 0C 07 E5 02 17 02 12
TX: 14:49:00 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 01
RX: 14:49:05 C4 02 C1 00 00 00 00 01
Byte array hex: C4 02 C1 00 00 00 00 01
[210224 14:49:05] There was an error while reading meter id = 197 position error, value = 10 and length of array = 8.
In reply to Authentication: by Ugurcan
Are you sure that you don't remove any data? Read is correct, but it seems like there is a header missing from the meter reply.
DATA is missing here: C4 01 C1 00 09 2C 42 4C 00 01 00 01 00 01 00
If this is really what the meter replies then there is an error in the meter.
In reply to And another one: by Ugurcan
Have you modified the code? You are asking the next block, but the meter didn't reply or it's missing here. There should be a timeout error if the meter is not answering.
Same thing here. The header is missing. Check that you don't remove it.
Ugurcan
Hello again, thanks for your
Hello again, thanks for your super fast replies. This is the full output. Meter actually replied here. Just there was a line that I printed in between.
I am not doing anything to remove the header in any of this calls. I don't even know what exactly you meant by header also. Can you elaborate a litte please?
Quarterly data reading of meter 197
Check this with some sniffer tool, but if this is what your meters really returns then there is a error in the meter and you need to ask meter manufacturer to fix it.
This is not a correct reply. That is the only payload (PDU) and the header is missing. There is nothing that you can do about it.
