  3. Error ServiceNotSupported For Some Actaris ACE6000 and SL7000
Error ServiceNotSupported for some Actaris ACE6000 and SL7000
By Davenzo , 22 February, 2021
I have a problem with some Actaris but not all of them,
when I read the clock with the following commands:
7EA01C0002002307327C5FE6E600C0011200080000010000FF0800F8377E
or
7EA01C0002002307544C59E6E600C0012200080000010000FF03009F407E
or
7EA01C0002002307765C5BE6E600C0013200080000010000FF020002287E
I get the following error:
7EA0120700020023527821E6E700D80102A7717E
which translated is:
<ExceptionResponse>
<StateError Value="ServiceNotAllowed" />
<ServiceError Value="ServiceNotSupported" />
</ExceptionResponse>
I do not understand if the clock is not readable for some specific meters and why I can read it in others.
Is there a way for me to get through this specific request without getting an exception?
Thank you very much
5 years 5 months ago
Is this the only command that you are sending? Are all the meters using the same firmware version?
Davenzo
This is the first GetRequest I am sending, before that I send the association request in order to connect to the meter but nothing else. This works for most of the Actaris I am reading.
The firmware is not the same,
4.73 is the firmware of a meter I can read
6.11 is the firmware of a meter I cannot read
Thank you very much
What programming language library you are using?
Make sure that you have selected "Get" -proposed conformance.
Davenzo
I am using a library based on iCube on Java.
I asked for a working call of the same command:
My command (not working)
7EA01C0002002307365819E6E600C0011200080000010000FF020088CA7E
<HDLC len="27" >
<TargetAddress Value="16401" />
<SourceAddress Value="3" />
<!--I frame.-->
<FrameType Value="36" />
<PDU>
<GetRequest>
<GetRequestNormal>
<!--Priority: NORMAL ServiceClass: UN_CONFIRMED invokeID: 2-->
<InvokeIdAndPriority Value="18" />
<AttributeDescriptor>
<!--CLOCK-->
<ClassId Value="8" />
<!--0.0.1.0.0.255-->
<InstanceId Value="0000010000FF" />
<AttributeId Value="2" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
</PDU>
</HDLC>
Working command:
7EA01C000200230F769C95E6E600C0018100080000010000FF020065D77E
<HDLC len="27" >
<SourceAddress Value="7" />
<!--I frame.-->
<FrameType Value="76" />
<PDU>
<GetRequest>
<GetRequestNormal>
<!--Priority: HIGH ServiceClass: UN_CONFIRMED invokeID: 1-->
<InvokeIdAndPriority Value="129" />
<!--CLOCK-->
</GetRequestNormal>
</GetRequest>
</PDU>
</HDLC>
Here I can notice a few differences,
SourceAddress Value
FrameType Value
InvokeAndPriority
Could any of these fields be causing the issue for these specific Actaris but not for the others?
Thank you ver much
Change the library for Gurux java version. Support is better. :-)
In the beginning, you can try to change ServiceClass to Confirmed.
Data is correct. One of the settings is wrong and that is causing the problem.
I believe that Itron has improved or changed some functionality for the newer firmware.
  • Danielfaw
  • TcmLCyrzROrdrv…
  • Anas Zaatreh
  • QDeYZLrphMziQF…
  • sharrongm69
