  3. DLMS Server Simulator One Ip.with Multiple Ports
DLMS server simulator one ip.with multiple ports
By yl , 16 February, 2021
I am running dlms server simulator one ip with 300 different ports.
When i use my program to Connect Those ports concurrently. It looks like no response or fail request
But if i run simulator in 2 different ip back to normal.
Is.any parameter inside simulator i need to setup?
5 years 5 months ago
You don't need to set any parameters. Are those IP addresses on the same PC or do you have two PC?
Are you using C# or Java version?
yl
hi Mikko,
hi Mikko,
the same PC, i am using C# version
Do you have two NIC cards connected to your PC or do you try to connect from another PC?
yl
i only have 1 NIC card in my PC, I run server simulator in my PC use my localhost IP with 300 different ports, my program in another pc, the program use PC IP + port number connect to DLMS server to get data. but 90% of concurrent requests are failed.
but when i run 2 server simulators in 2 different PCs with 1 port only. the program in third PC use PC IP + port number connect to DLMS server to get data concurrently,100% successful without fail request.
bcz i am doing the performance test for my program , so i tot i can just use one ip with 300 ports to perform concurrent process.
  • Danielfaw
  • TcmLCyrzROrdrv…
  • Anas Zaatreh
  • QDeYZLrphMziQF…
  • sharrongm69
