  3. Image Transfer Through Action Schedule.
Image transfer through Action Schedule.
By Ashok_Chowdary , 8 January, 2021
We are facing image transfer through actionSchedule . image transfer not happening after given time.
if i try to read after given Activate time completed it throws Hardware fault error. and disconnecting the client.
please check the log
help me where is the problem.
13:21:38 Read object type ImageTransfer index: 2
TX: 7E A0 19 03 61 76 29 9A E6 E6 00 C0 01 C1 00 12 00 00 2C 00 00 FF 02 00 7B B1 7E
13:21:38
RX: 7E A0 15 61 03 96 03 0C E6 E7 00 C4 01 C1 00 06 00 00 00 C0 71 DE 7E
13:21:38 Read object type ImageTransfer index: 3
TX: 7E A0 19 03 61 98 59 94 E6 E6 00 C0 01 C1 00 12 00 00 2C 00 00 FF 03 00 A3 A8 7E
13:21:38
RX: 7E A0 A1 61 03 B8 0F D7 E6 E7 00 C4 01 C1 00 04 82 04 61 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 80 9C AA 7E
13:21:38 Read object type ImageTransfer index: 4
TX: 7E A0 19 03 61 BA 49 96 E6 E6 00 C0 01 C1 00 12 00 00 2C 00 00 FF 04 00 AB E5 7E
13:21:38
RX: 7E A0 15 61 03 DA 6B 84 E6 E7 00 C4 01 C1 00 06 00 00 04 61 92 0D 7E
13:21:38 Read object type ImageTransfer index: 5
TX: 7E A0 19 03 61 DC 79 90 E6 E6 00 C0 01 C1 00 12 00 00 2C 00 00 FF 05 00 73 FC 7E
13:21:38
RX: 7E A0 12 61 03 FC 7E 97 E6 E7 00 C4 01 C1 00 03 01 B3 FA 7E
13:21:38 Read object type ImageTransfer index: 6
TX: 7E A0 19 03 61 FE 69 92 E6 E6 00 C0 01 C1 00 12 00 00 2C 00 00 FF 06 00 1B D6 7E
13:21:39
RX: 7E A0 12 61 03 1E 62 53 E6 E7 00 C4 01 C1 00 16 03 88 32 7E
13:21:39 Read object type ImageTransfer index: 7
TX: 7E A0 19 03 61 10 19 9C E6 E6 00 C0 01 C1 00 12 00 00 2C 00 00 FF 07 00 C3 CF 7E
13:21:39
RX: 7E A0 11 61 03 30 D3 BE E6 E7 00 C4 01 C1 01 01 61 A1 7E
13:21:41 Disconnect request
TX: 7E A0 07 03 61 53 65 81 7E
13:21:41
RX: 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 F0 06 01 F0 07 04 00 00 00 01 08 04 00 00 00 01 F9 CB 7E
Ashok K
Ashok_Chowdary
5 years 6 months ago
Hi mikko,
Hi mikko,
I am waiting for your reply,
here problem is image transfer through script it is working fine. but, through Action schedule it is not happening
Have you created Script Table object 0.0.10.0.107.255 and Action schedule object 0.0.15.0.2.255?
Is the Action schedule calling the Script Table object? Have you add scripts that call Activate, Verify and Update actions of the Image transfer object?
Ashok_Chowdary
5 years 5 months ago
I am having another problem on Image transfer
I gave certain time to activate image through Action schedule-imageActivation, at that time period my meter has no power.then when meter have power image should activate through Action schedule after meter got power.
it is not happening in my case.
please help me how can I achieve this.
After you have uploaded the image you call the action #1 of the Action schedule 0.0.15.0.2.255.
Some meter manufacturers set time to *.*.* 00.00.00 and the image is activated after the boot, but you need to ask this from the meter manufacturer.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
