  3. Read 0.0.43.0.0.255 Index 2,6 - Error
Read 0.0.43.0.0.255 index 2,6 - error
By MNN , 9 February, 2021
Gurux.DLMS.AMI
Hello.
When reading 0.0.43.0.255, errors occur when reading attributes 2 and 6:
Reading: 0.0.43.0.0.255
TX: 02:53:59 7E A0 19 03 0F 32 4C 61 E6 E6 00 C0 01 C1 00 40 00 00 2B 00 00 FF 02 00 A7 2F 7E
RX: 02:53:59 7E A0 12 0F 03 52 5C CE E6 E7 00 C4 01 C1 00 16 04 37 46 7E
fail: Gurux.DLMS.AMI.Reader.ReaderService[0]
Failed to Read 0.0.43.0.0.255:2. Index (zero based) must be greater than or equal to zero and less than the size of the argument list.
warn: Gurux.DLMS.AMI.Scheduler.GXSchedulerService[0]
Timed Background Service is working.
TX: 02:54:00 7E A0 19 03 0F 54 7C 67 E6 E6 00 C0 01 C1 00 40 00 00 2B 00 00 FF 03 00 7F 36 7E
RX: 02:54:00 7E A0 12 0F 03 74 68 8A E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
TX: 02:54:00 7E A0 19 03 0F 76 6C 65 E6 E6 00 C0 01 C1 00 40 00 00 2B 00 00 FF 04 00 77 7B 7E
RX: 02:54:00 7E A0 1A 0F 03 96 AC AB E6 E7 00 C4 01 C1 00 09 08 00 00 00 00 00 00 00 00 9F 52 7E
TX: 02:54:00 7E A0 19 03 0F 98 1C 6B E6 E6 00 C0 01 C1 00 40 00 00 2B 00 00 FF 05 00 AF 62 7E
RX: 02:54:00 7E A0 1A 0F 03 B8 D0 63 E6 E7 00 C4 01 C1 00 09 08 45 4D 52 00 01 BA 81 60 E0 12 7E
TX: 02:54:00 7E A0 19 03 0F BA 0C 69 E6 E6 00 C0 01 C1 00 40 00 00 2B 00 00 FF 06 00 C7 48 7E
RX: 02:54:00 7E A0 65 0F 03 DA 78 CB E6 E7 00 C4 01 C1 00 01 02 02 06 16 31 16 32 09 0A 33 34 35 36 37 38 39 30 61 62 09 06 63 64 65 66 67 68 09 06 69 67 6B 6A 6D 6E 09 06 6F 70 71 72 00 00 02 06 16 00 16 00 09 0A 00 00 00 00 00 00 00 00 00 00 09 07 00 00 00 00 00 00 00 09 0A 00 00 00 00 00 00 00 00 00 00 09 00 4A A4 7E
Failed to Read 0.0.43.0.0.255:6. GetDataType failed. Invalid attribute index.
5 years 4 months ago
Your version of the Security setup object is zero in the database and you try to read the meter that is using Security setup version one. I checked this and the version number is updated correctly to the database. Have you created the template with a different device?
The only way to solve this at the moment is if you change the version number from zero to one for this security setup object or read the association view again from the meter and add the device template again.
MNN
Thank you.
Thank you.
Is it a setting in device properties? Can I change this setting via the interface AMI?
This object in the database has version 1.
5 years 3 months ago
This is fixed. Get the latest version and let me know if you have problems. We are just adding support for Securit Suite 1 and 2.
MNN
Thank you!
Thank you!
