  3. Push Configuration: Class 40
Push configuration: class 40
By sesaomz , 14 January, 2021
I am developing class40 object. For the attribute number 3 "send_destination_and_method" I have to set the IP address of the connected management client. When I browse for it in the following object (image) but I can't see the field in which I have this IP address. ¿Where can I see it in gxdirector??
Thanks a lot for your help!!
5 years 4 months ago
This information is available in Push Setup object, not in Association Logican Name object.
sesaomz
Thanks for your response. The fact is that in the server, for push operation, I have to use the DLMS association context that is active for a management client when the push operation starts. So I have somehow to extract the destination IP from the association object, and I can't see where.
Thanks in advance one more time!
5 years 3 months ago
In reply to Hi, by sesaomz
I'm sorry for the slow reply. I was missed a few questions. The IP address is not tight to the association object.
You might add several push objects. One for each association view to handle this.
