  3. Meter Connect Success But Register Reading Fail
Meter Connect Success but Register Reading Fail
By abu3bdullah , 22 October, 2020
I am connecting to the Meter using "Serial over Ethernet", the connection is successfully done.
When I try to read for example the "1.0.1.8.0.255" register, DLMSDirector is sending and receiving without any problems, but I don't have any values.
When I repeat the "Read" process about three times, I receive "" then connect again to meter and "Read" again it I receive correct value !
14:45:09 Read object type Register index: 2
TX: 7E A0 1C 00 02 66 0D 07 32 22 9E E6 E6 00 C0 01 C1 00 03 01 00 01 08 00 FF 02 00 32 68 7E
"No Value is got here"
14:45:10
RX:
7E A0 2A 07 00 02 66 0D 03 65 00 E6 E7 00 C2 09 0C 07 E4 0A 16 04 0E 2D 10 00 80 00 00 00 01 00 00 61 61 04 FF 02 04 08 40 04 CE 7E
"Value is received"
14:48:33
RX:
7E A0 1C 07 00 02 66 0D 52 EE CD E6 E7 00 C4 01 C1 00 15 00 00 00 00 00 2C BA F1 50 C0 7E
The problem is repetitive, and I tried for many meters and have the same behavior. But sometimes I receive the value from the first "Read".
5 years 11 months ago
You are receiving GatewayRequest and the HDLC frame is the supervisory frame. This is wrong and the client accepts it as a reply. Are you communicating directly with the meter or is there a gateway in the middle?
abu3bdullah
5 years 10 months ago
Yes I am just using a "Serial
Yes I am just using a "Serial to Ethernet" Converter in the middle.
Meter:RS485 > Converter > IP:Port
The serial port of the converter is mapped to IP & Port, I am using "Serial over Ethernet" option in Gurux configuration.
It was working most of the time, but sometimes I have this behavior.
abu3bdullah
5 years 8 months ago
Still this issue I have with
Still this issue I have with Gurux.AMI
Please can you consider ?
The value is stored in the DB as Empty value ' '
And it is almost repeated for 1 meter of 176, sometimes the problem shows in other meters but less often.
Your meter is sending EventNotificationReques where HDLC sequence ID is 3. We have improved this and the new version is released at the beginning of January.
