  3. EMH LZQJ-XC Icw Variomod-XC LTE
EMH LZQJ-XC icw Variomod-XC LTE
By dntimmie , 17 September, 2020
I have a EMH LZQJ-XC in combination with the EMH Variomod-XC LTE. I can connect to the meter with their software (Combimaster), but not with Gurux DLMS Director. All setting are OK. Beneath the log if I connect:
07:49:19 07:49:19.756 Info Opening
07:49:19 07:49:19.756 Info Client Settings: Protocol Tcp Host: 188.207.43.244 Port: 8000
07:49:20 07:49:20.346 Info Open
07:49:20 Send SNRM request.
TX: 7E A0 0A 00 02 7E 73 41 93 A9 63 7E
07:49:20 07:49:20.856 Sent 7E A0 0A 00 02 7E 73 41 93 A9 63 7E
07:49:30 Failed to receive reply from the device in given time.
07:49:30 Send Disconnect request.
TX: 7E A0 0A 00 02 7E 73 41 53 A5 A5 7E
07:49:30 07:49:30.870 Sent 7E A0 0A 00 02 7E 73 41 53 A5 A5 7E
07:49:40 Failed to receive reply from the device in given time.
07:49:40 07:49:40.878 Info Closing
07:49:40 07:49:40.878 Info Closed
What could cause the problem?
5 years 10 months ago
Change the Logical server from 10 to 0. Is 10077865 serial number of the meter?
dntimmie
EMH came with the following
EMH came with the following solution: Unselect Create 7E1 parity. I can now connect to the meter and all parameters. Thank you.
Solved.
So you are not using direct TCP/IP connection to the meter. You have Moxa, etc in the middle.
I'm glad that this is solved. Serial port settings might sometimes cause a lot of pain.
  • brainstormkale…
  • Vegazone-au
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
