  3. Python: TimeZone Class
Python: TimeZone class
By youserj , 2 September, 2020
I want to suggest rewriting the (because i can't make deepcopy GXDateTime: missing Offset)
class GXTimeZone:
def __new__(cls, offset):
local_time_delta = datetime.timedelta(minutes=offset)
if offset == 0:
name = "Z"
else:
if offset > 0:
name = "+"
else:
name = "-"
name += str(int(offset / 60)).zfill(2)
name += ":"
name += str(offset % 60).zfill(2)
time_zone = datetime.timezone(local_time_delta, name)
return time_zone
6 years 2 months ago
Can you tell me a little bit more about what you want to do? Time zone information is created when the value is read from the meter to kept the meter's time zone information.
youserj
I copy objects from several
I copy objects from several servers in one inheritable class. I changing it by widgets and send back. For copy i use copy.deepcopy
